Ana içeriğe geç
Gateway W350I RAM Replacement
Neye ihtiyacın var
  1. Gateway W350I RAM Replacement, Battery Access: adım 1, 1 resimden 1.
    • Turn the laptop upside down and position it as shown in the image.
    FixBot'a Sor
    Yorum Ekle
  2. Gateway W350I RAM Replacement, Unlocking the Battery: adım 2, 3 resimden 1. Gateway W350I RAM Replacement, Unlocking the Battery: adım 2, 3 resimden 2. Gateway W350I RAM Replacement, Unlocking the Battery: adım 2, 3 resimden 3.
    • Slide the locking switch towards the open lock picture.
    • Hold the release switch in the unlocked position while simultaneously pushing the battery away from the laptop.
    • Once the laptop is disengaged, completely remove the battery from the laptop.
    FixBot'a Sor
    Yorum Ekle
  3. Gateway W350I RAM Replacement, Remove Bottom Cover: adım 3, 3 resimden 1. Gateway W350I RAM Replacement, Remove Bottom Cover: adım 3, 3 resimden 2. Gateway W350I RAM Replacement, Remove Bottom Cover: adım 3, 3 resimden 3.
    • Turn the laptop over to remove the plastic cover.
    • Remove the single 3mm Phillips #0 screw holding on the plastic cover.
    • Use a plastic opening tool to gently pry off the plastic cover.
    FixBot'a Sor
    Yorum Ekle
  4. Gateway W350I RAM Replacement, Removing RAM Chips: adım 4, 3 resimden 1. Gateway W350I RAM Replacement, Removing RAM Chips: adım 4, 3 resimden 2. Gateway W350I RAM Replacement, Removing RAM Chips: adım 4, 3 resimden 3.
    • Gently pull the first RAM chip to slide it free from the mounting on the board.
    • Gently pull the second RAM chip, located under the first, to slide it free from the mounting on the board.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Aaron Austin
252 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 4-1, Brown Fall 2014 USF Tampa, Team 4-1, Brown Fall 2014 üyesi
USFT-BROWN-F14S4G1
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 33
Her zaman: 2,214
