Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
Repair the damper assembly door rather than replacing the entire assembly.
Neye ihtiyacın var
Videoya Genel Bakış
This video is about repairing a broken damper doo rather than replacing the regulator assembly.
Empty Fridge, remove the regulator at the top rear of the fridge, check and see if its a broken damper door. assuming it is remove the damper motor assembly with the broken door and use a heat gun to weld them back together. adjust the assembly as needed and replace the damper assembly and test.
Bir başkası bu kılavuzu tamamladı.
