Ana içeriğe geç
GeeksPhone Keon Battery Replacement
Neye ihtiyacın var
  1. GeeksPhone Keon Battery Replacement, Battery: adım 1, 2 resimden 1. GeeksPhone Keon Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Insert the plastic opening tool into the seam between the front of the device and the rear cover.
    • Slide the plastic opening tool from the bottom of the phone to the top.
    • Use the plastic opening tool to free all the clips attached to the phone.
    FixBot'a Sor
    Yorum Ekle
  2. GeeksPhone Keon Battery Replacement: adım 2, 1 resimden 1.
    • Lift the cover away from the phone.
    FixBot'a Sor
    Yorum Ekle
  3. GeeksPhone Keon Battery Replacement: adım 3, 1 resimden 1.
    • Insert the plastic opening tool into the groove between the bottom of the phone and the battery.
    • Lift the battery with the plastic opening tool and finish removing battery by hand.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Yanni Worthington
343 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 3-5, Eyestone Fall 2015 USF Tampa, Team 3-5, Eyestone Fall 2015 üyesi
USFT-EYESTONE-F15S3G5
4 Üyeler
18 adet Kılavuz yazıldı
4Kılavuz Yorumları
Newer Keon model has user replaceable battery GP-BA002
gintasdx - Yanıt Paylaş
Newer Keon model has a user replaceable battery Li-ion GP-BA002 3.7V 1580mAh .
GP-BA002: Li-ion, 3.7V ,1580mAh, Limited charge voltage 4.2v, with dimensions: 5.1x5.1x0.5cm, its a four pin battery, the pinout es: Negative, BSI, BTemp, Positive, both negative and positive al labeled on the front of the batery the other two not, BTemp is a 10k oms resistor and BSI reads 47k oms on a discharged battery
Diego Gomez - Yanıt Paylaş
Has anybody found another battery that is compatible with the GP-BA002?
ecloud - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 34
Her zaman: 1,041
