Ana içeriğe geç
GeeksPhone Keon Motherboard Replacement
Neye ihtiyacın var
  1. GeeksPhone Keon Motherboard Replacement, Battery: adım 1, 2 resimden 1. GeeksPhone Keon Motherboard Replacement, Battery: adım 1, 2 resimden 2.
    • Insert the plastic opening tool into the seam between the front of the device and the rear cover.
    • Slide the plastic opening tool from the bottom of the phone to the top.
    • Use the plastic opening tool to free all the clips attached to the phone.
    FixBot'a Sor
    Yorum Ekle
  2. GeeksPhone Keon Motherboard Replacement: adım 2, 1 resimden 1.
    • Lift the cover away from the phone.
    FixBot'a Sor
    Yorum Ekle
  3. GeeksPhone Keon Motherboard Replacement: adım 3, 1 resimden 1.
    • Insert the plastic opening tool into the groove between the bottom of the phone and the battery.
    • Lift the battery with the plastic opening tool and finish removing battery by hand.
    FixBot'a Sor
    Yorum Ekle
  4. GeeksPhone Keon Motherboard Replacement, Back Plate: adım 4, 2 resimden 1. GeeksPhone Keon Motherboard Replacement, Back Plate: adım 4, 2 resimden 2.
    • Remove the two 5mm T4 screws on the sides of the small orange plate.
    FixBot'a Sor
    Yorum Ekle
  5. GeeksPhone Keon Motherboard Replacement: adım 5, 2 resimden 1. GeeksPhone Keon Motherboard Replacement: adım 5, 2 resimden 2.
    • Gently remove the small orange plate by pulling it down.
    FixBot'a Sor
    Yorum Ekle
  6. GeeksPhone Keon Motherboard Replacement: adım 6, 1 resimden 1.
    • Remove the following screws securing the back plate to the device:
    • Two silver 2mm T3 screws
    • Five black 3mm T3 screws
    FixBot'a Sor
    Yorum Ekle
  7. GeeksPhone Keon Motherboard Replacement: adım 7, 3 resimden 1. GeeksPhone Keon Motherboard Replacement: adım 7, 3 resimden 2. GeeksPhone Keon Motherboard Replacement: adım 7, 3 resimden 3.
    • Slightly lift up the bottom corner of the backplate.
    • Release the four clips on both sides by pulling them away from the device.
    FixBot'a Sor
    Yorum Ekle
  8. GeeksPhone Keon Motherboard Replacement: adım 8, 2 resimden 1. GeeksPhone Keon Motherboard Replacement: adım 8, 2 resimden 2.
    • Lift the backplate away from the device.
    FixBot'a Sor
    Yorum Ekle
  9. GeeksPhone Keon Motherboard Replacement, Motherboard: adım 9, 2 resimden 1. GeeksPhone Keon Motherboard Replacement, Motherboard: adım 9, 2 resimden 2.
    • Remove the three connections from the back of the motherboard by using the tip of a spudger or your fingernail to flip up the small retaining flap. Then pull the ribbon cable out.
    • Remove the wire from the bottom left of the motherboard by lifting it away from the device.
    • Remove the 2mm T3 screw in the upper left corner of the motherboard.
    FixBot'a Sor
    Yorum Ekle
  10. GeeksPhone Keon Motherboard Replacement: adım 10, 1 resimden 1.
    • Lift the motherboard and remove the connector on the back by using the tip of a spudger or your fingernail to flip up the small retaining flap. Then pull the ribbon cable out.
    FixBot'a Sor
    Yorum Ekle
  11. GeeksPhone Keon Motherboard Replacement: adım 11, 1 resimden 1.
    • Remove the motherboard from the device.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Yanni Worthington
343 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 3-5, Eyestone Fall 2015 USF Tampa, Team 3-5, Eyestone Fall 2015 üyesi
USFT-EYESTONE-F15S3G5
4 Üyeler
18 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 29
Her zaman: 444
