Ana içeriğe geç
GeeksPhone Keon Screen Replacement
Neye ihtiyacın var
  1. GeeksPhone Keon Screen Replacement, Battery: adım 1, 2 resimden 1. GeeksPhone Keon Screen Replacement, Battery: adım 1, 2 resimden 2.
    • Insert the plastic opening tool into the seam between the front of the device and the rear cover.
    • Slide the plastic opening tool from the bottom of the phone to the top.
    • Use the plastic opening tool to free all the clips attached to the phone.
    FixBot'a Sor
  2. GeeksPhone Keon Screen Replacement: adım 2, 1 resimden 1.
    • Lift the cover away from the phone.
    FixBot'a Sor
  3. GeeksPhone Keon Screen Replacement: adım 3, 1 resimden 1.
    • Insert the plastic opening tool into the groove between the bottom of the phone and the battery.
    • Lift the battery with the plastic opening tool and finish removing battery by hand.
    FixBot'a Sor
  4. GeeksPhone Keon Screen Replacement, Back Plate: adım 4, 2 resimden 1. GeeksPhone Keon Screen Replacement, Back Plate: adım 4, 2 resimden 2.
    • Remove the two 5mm T4 screws on the sides of the small orange plate.
    FixBot'a Sor
  5. GeeksPhone Keon Screen Replacement: adım 5, 2 resimden 1. GeeksPhone Keon Screen Replacement: adım 5, 2 resimden 2.
    • Gently remove the small orange plate by pulling it down.
    FixBot'a Sor
  6. GeeksPhone Keon Screen Replacement: adım 6, 1 resimden 1.
    • Remove the following screws securing the back plate to the device:
    • Two silver 2mm T3 screws
    • Five black 3mm T3 screws
    FixBot'a Sor
  7. GeeksPhone Keon Screen Replacement: adım 7, 3 resimden 1. GeeksPhone Keon Screen Replacement: adım 7, 3 resimden 2. GeeksPhone Keon Screen Replacement: adım 7, 3 resimden 3.
    • Slightly lift up the bottom corner of the backplate.
    • Release the four clips on both sides by pulling them away from the device.
    FixBot'a Sor
  8. GeeksPhone Keon Screen Replacement: adım 8, 2 resimden 1. GeeksPhone Keon Screen Replacement: adım 8, 2 resimden 2.
    • Lift the backplate away from the device.
    FixBot'a Sor
  9. GeeksPhone Keon Screen Replacement, Motherboard: adım 9, 2 resimden 1. GeeksPhone Keon Screen Replacement, Motherboard: adım 9, 2 resimden 2.
    • Remove the three connections from the back of the motherboard by using the tip of a spudger or your fingernail to flip up the small retaining flap. Then pull the ribbon cable out.
    • Remove the wire from the bottom left of the motherboard by lifting it away from the device.
    • Remove the 2mm T3 screw in the upper left corner of the motherboard.
    FixBot'a Sor
  10. GeeksPhone Keon Screen Replacement: adım 10, 1 resimden 1.
    • Lift the motherboard and remove the connector on the back by using the tip of a spudger or your fingernail to flip up the small retaining flap. Then pull the ribbon cable out.
    FixBot'a Sor
  11. GeeksPhone Keon Screen Replacement: adım 11, 1 resimden 1.
    • Remove the motherboard from the device.
    FixBot'a Sor
  12. GeeksPhone Keon Screen Replacement, Antenna: adım 12, 1 resimden 1.
    • Unfasten the black wire from the metal clamps by hand and lift the black wire away from the device.
    • Unfasten the plastic clamps attached to the antenna.
    FixBot'a Sor
  13. GeeksPhone Keon Screen Replacement: adım 13, 3 resimden 1. GeeksPhone Keon Screen Replacement: adım 13, 3 resimden 2. GeeksPhone Keon Screen Replacement: adım 13, 3 resimden 3.
    • Gently lift the antenna and flip it over to reveal a ZIF connector on the back.
    • Flip up the small retaining flap on the ZIF connector and pull the ribbon cable out.
    FixBot'a Sor
  14. GeeksPhone Keon Screen Replacement, Screen: adım 14, 2 resimden 1. GeeksPhone Keon Screen Replacement, Screen: adım 14, 2 resimden 2.
    • Use the metal spudger to gently lift up the back of the screen.
    FixBot'a Sor
  15. GeeksPhone Keon Screen Replacement: adım 15, 2 resimden 1. GeeksPhone Keon Screen Replacement: adım 15, 2 resimden 2.
    • Continue to lift up the screen until it is loose from the device.
    FixBot'a Sor
Sonuç
Bir başkası bu kılavuzu tamamladı.
DavidDrash
266 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 3-5, Eyestone Fall 2015 USF Tampa, Team 3-5, Eyestone Fall 2015 üyesi
USFT-EYESTONE-F15S3G5
4 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 36
Her zaman: 391
