Neye ihtiyacın var
The four screws on the back should be removed in a cross pattern and use a Phillips screwdriver
If you have tweezers use them and make sure to be careful and to pull up on the connector and not the wires or the base as both risk damaging the device.
To reassemble your device, follow these instructions in reverse order and make sure to use the cross pattern when reserving the back screws holding the fan in place.
Bir başkası bu kılavuzu tamamladı.
