Ana içeriğe geç
General Disassembly LG VX8560
Neye ihtiyacın var
  1. General Disassembly LG VX8560, General Disassembly LG VX8560: adım 1, 1 resimden 1.
    • Flip phone over so its backside is facing up.
  2. General Disassembly LG VX8560: adım 2, 1 resimden 1.
    • Push from indentation and slide battery cover away from phone to remove battery cover.
  3. General Disassembly LG VX8560: adım 3, 1 resimden 1.
    • Take out the battery once cover is off by gently prying with your fingers.
  4. General Disassembly LG VX8560: adım 4, 1 resimden 1.
    • Using a philips screwdriver, unscrew all 4 screws along the edge of the phone
  5. General Disassembly LG VX8560: adım 5, 2 resimden 1. General Disassembly LG VX8560: adım 5, 2 resimden 2.
    • Using your plastic pry tool, insert the tool between the phone’s keypad cover and back cover and gently pry apart.
  6. General Disassembly LG VX8560: adım 6, 1 resimden 1.
    • Once the covers have been separated the motherboard will be visible. Do not separate the two covers completely. The covers will be held together by a screw on the axis of the phone.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jack Foley
37 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-62, Johann Spring 2013 Cal Poly, Team 13-62, Johann Spring 2013 üyesi
CPSU-JOHANN-S13S13G62
4 Üyeler
12 adet Kılavuz yazıldı
Bir Yorum
Concerning a LG Chocolate 3 still activated and perfectly working but with a damaged frame. Can you take the activated internal parts out of a damaged frame phone and install in a like new condition identical phone frame ?
Zamora - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 396
