Ana içeriğe geç
General Electric Create Jason Wu LCD Screen Replacement
Neye ihtiyacın var
  1. General Electric Create Jason Wu LCD Screen Replacement, General Electric Create Jason Wu Casing Disassembly: adım 1, 3 resimden 1. General Electric Create Jason Wu LCD Screen Replacement, General Electric Create Jason Wu Casing Disassembly: adım 1, 3 resimden 2. General Electric Create Jason Wu LCD Screen Replacement, General Electric Create Jason Wu Casing Disassembly: adım 1, 3 resimden 3.
    • Begin by removing the 5 screws (located: 2 screws on either side and 1 screw on the bottom) using the PH000 head in the Precision Phillips Screwdriver.
    • These screws were missing in our example. These screws should have been small Phillips PH000 screws 1.5mm in length.
    • These screws are very small. To keep from losing any pieces, place all small metals on a magnetic project mat.
  2. General Electric Create Jason Wu LCD Screen Replacement: adım 2, 2 resimden 1. General Electric Create Jason Wu LCD Screen Replacement: adım 2, 2 resimden 2.
    • After the screws are removed, pull the front casing up and away from the camera.
    • If the casing is difficult to remove, use a plastic opening tool to gently pry up on the front as shown.
  3. General Electric Create Jason Wu LCD Screen Replacement: adım 3, 3 resimden 1. General Electric Create Jason Wu LCD Screen Replacement: adım 3, 3 resimden 2. General Electric Create Jason Wu LCD Screen Replacement: adım 3, 3 resimden 3.
    • Using your hands or an opening tool, pry off the silver frame, taking special care at the top of the camera where the buttons are as it is a little harder to pry off.
    • If the back casing is loose from the camera body, it may be easier to perform step 4 first, then accomplish this step. Proceed as your unit allows.
  4. General Electric Create Jason Wu LCD Screen Replacement: adım 4, 3 resimden 1. General Electric Create Jason Wu LCD Screen Replacement: adım 4, 3 resimden 2. General Electric Create Jason Wu LCD Screen Replacement: adım 4, 3 resimden 3.
    • The last part of the casing to disconnect is the back that houses the LCD screen.
    • The screen is attached by a connection ribbon. Gently pull the casing and screen away from the camera body to disconnect the casing.
    • The LCD screen is held onto the back casing by a small amount of adhesive. This may come loose during this process. Do not worry if they become separated.
    • This plug and the connection ribbon are fragile, try not to tear the connection ribbon when disconnecting.
  5. General Electric Create Jason Wu LCD Screen Replacement, LCD Screen: adım 5, 2 resimden 1. General Electric Create Jason Wu LCD Screen Replacement, LCD Screen: adım 5, 2 resimden 2.
    • With the back casing that you just separated from the camera, use your finger to push the LCD screen from the frame.
    • The LCD screen is secured to the frame with a thin layer of adhesive, not much force is required to removed the screen from the back casing.
    • Before replacing the back casing with the new LCD screen, please be sure it is secured into the casing with new adhesive.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 11
Her zaman: 163
