Ana içeriğe geç
Generic TV Remote IR LED Replacement
Neye ihtiyacın var
  1. Generic TV Remote IR LED Replacement, IR LED: adım 1, 2 resimden 1. Generic TV Remote IR LED Replacement, IR LED: adım 1, 2 resimden 2.
    • Starting to the side of the front LED, pry up the top of the remote.
    • Remove the top of the remote to expose the circuit board.
    FixBot'a Sor
  2. Generic TV Remote IR LED Replacement: adım 2, 3 resimden 1. Generic TV Remote IR LED Replacement: adım 2, 3 resimden 2. Generic TV Remote IR LED Replacement: adım 2, 3 resimden 3.
    • Remove the circuit board by gently lifting it from the casing.
    • Flip over the board so that the leads of the LED are facing upward.
    FixBot'a Sor
  3. Generic TV Remote IR LED Replacement: adım 3, 1 resimden 1.
    • Clip the leads of the LED.
    • Bend the LED downward until it makes a 90 degree angle with the circuit board.
    FixBot'a Sor
  4. Generic TV Remote IR LED Replacement: adım 4, 1 resimden 1.
    • Desolder the broken LED using a soldering iron and desoldering braid.
    FixBot'a Sor
  5. Generic TV Remote IR LED Replacement: adım 5, 1 resimden 1.
    • Solder the new LED in the same spot as the old one.
    • Make sure that the longer lead (positive) goes through the opening marked positive (+) before soldering.
    FixBot'a Sor
  6. Generic TV Remote IR LED Replacement: adım 6, 3 resimden 1. Generic TV Remote IR LED Replacement: adım 6, 3 resimden 2. Generic TV Remote IR LED Replacement: adım 6, 3 resimden 3.
    • Make sure the buttons and the circuit board are placed correctly before reassembly.
    FixBot'a Sor
  7. Generic TV Remote IR LED Replacement: adım 7, 1 resimden 1.
    • To check if your remote is now working, first make sure the batteries are in correctly. Then, press any button and aim the remote at a smartphone camera. If the LED is working, a red flashing light will be reflected in the camera.
    FixBot'a Sor
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 18
Son 30 gün: 100
Her zaman: 15,131
