Ana içeriğe geç
Genesis II CSS-315 Ignitor Replacement
Neye ihtiyacın var
  1. Genesis II CSS-315 Ignitor Replacement, Ignitor: adım 1, 2 resimden 1. Genesis II CSS-315 Ignitor Replacement, Ignitor: adım 1, 2 resimden 2.
    • Be sure the grill is turned off before beginning this guide.
    • Remove all of the control knobs.
    • The amount of knobs may vary depending on the grill.
  2. Genesis II CSS-315 Ignitor Replacement: adım 2, 2 resimden 1. Genesis II CSS-315 Ignitor Replacement: adım 2, 2 resimden 2.
    • Remove the two 19 mm screws below the control knob panel using a Phillips #3 screwdriver.
  3. Genesis II CSS-315 Ignitor Replacement: adım 3, 2 resimden 1. Genesis II CSS-315 Ignitor Replacement: adım 3, 2 resimden 2.
    • Push up on the front panel, and pull it up above the grill.
    • Potential for device damage: The ignitor is connected to the front panel, so do not pull too hard.
  4. Genesis II CSS-315 Ignitor Replacement: adım 4, 2 resimden 1. Genesis II CSS-315 Ignitor Replacement: adım 4, 2 resimden 2.
    • Disconnect the cables from the ignitor.
  5. Genesis II CSS-315 Ignitor Replacement: adım 5, 1 resimden 1.
    • Pinch the two ends of the ignitor and remove the ignitor from the front panel.
  6. Genesis II CSS-315 Ignitor Replacement: adım 6, 1 resimden 1.
    • Have the new ignitor on hand, and make sure that the clips on the side are in good condition.
    • Ensure that the pins at the end are straight and not bent.
  7. Genesis II CSS-315 Ignitor Replacement: adım 7, 3 resimden 1. Genesis II CSS-315 Ignitor Replacement: adım 7, 3 resimden 2. Genesis II CSS-315 Ignitor Replacement: adım 7, 3 resimden 3.
    • Put the new ignitor into the socket.
    • Press down evenly until it is secure.
  8. Genesis II CSS-315 Ignitor Replacement: adım 8, 1 resimden 1.
    • Connect the white cables to the ignitor.
  9. Genesis II CSS-315 Ignitor Replacement: adım 9, 2 resimden 1. Genesis II CSS-315 Ignitor Replacement: adım 9, 2 resimden 2.
    • Make sure any and all cables are separated from the fire box (the bottom of the grill).
    • Slot the panel back on the grill and then push downward.
    • The fire box is the part of the grill that gets really hot, and this can damage the cables.
  10. Genesis II CSS-315 Ignitor Replacement: adım 10, 1 resimden 1.
    • Make sure the holes match and reinsert the screws from Step 2 using a Phillips #3 screwdriver.
    • If the holes do not match up, you may have to gently push or pull the front plastic panel.
  11. Genesis II CSS-315 Ignitor Replacement: adım 11, 2 resimden 1. Genesis II CSS-315 Ignitor Replacement: adım 11, 2 resimden 2.
    • Add the control knobs, and slot them into place.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
Carlos Castro Paguaga
253 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 25
Her zaman: 892
