Ana içeriğe geç
George Foreman GR-20 Disassembly
Neye ihtiyacın var
  1. George Foreman GR-20 Disassembly, George Foreman GR-20 Disassembly: adım 1, 2 resimden 1. George Foreman GR-20 Disassembly, George Foreman GR-20 Disassembly: adım 1, 2 resimden 2.
    • Open the grill and remove the two Phillips #2 screws from the top lid.
  2. George Foreman GR-20 Disassembly: adım 2, 3 resimden 1. George Foreman GR-20 Disassembly: adım 2, 3 resimden 2. George Foreman GR-20 Disassembly: adım 2, 3 resimden 3.
    • Using a pick, peel off the model number sticker to expose the two screws underneath. Remove these screws using a Phillips #2 screwdriver.
  3. George Foreman GR-20 Disassembly: adım 3, 2 resimden 1. George Foreman GR-20 Disassembly: adım 3, 2 resimden 2.
    • Remove the Phillips #2 screw from the orange tab.
    • Detach the top lid from the bottom of the grill.
  4. George Foreman GR-20 Disassembly: adım 4, 2 resimden 1. George Foreman GR-20 Disassembly: adım 4, 2 resimden 2.
    • To measure the resistance of the heating coil, disconnect the blue wire from the heating element.
  5. George Foreman GR-20 Disassembly: adım 5, 1 resimden 1.
    • To access the underside of the grill, flip the grill over and remove the rubber bottoms of the two front feet to expose the screws.
  6. George Foreman GR-20 Disassembly: adım 6, 1 resimden 1.
    • Remove the two screws using a Phillips #2 screwdriver.
  7. George Foreman GR-20 Disassembly: adım 7, 2 resimden 1. George Foreman GR-20 Disassembly: adım 7, 2 resimden 2.
    • Remove the two Phillips #2 screws in front of the two back feet.
  8. George Foreman GR-20 Disassembly: adım 8, 2 resimden 1. George Foreman GR-20 Disassembly: adım 8, 2 resimden 2.
    • To remove the power cord from the device, remove the two Phillips #2 screws keeping the power cord and the blue and white wires connected.
  9. George Foreman GR-20 Disassembly: adım 9, 1 resimden 1.
    • After removing the screws, slide the blue and white wires out through the gap.
    • You will now have access to the underside of the grill.
  10. George Foreman GR-20 Disassembly: adım 10, 2 resimden 1. George Foreman GR-20 Disassembly: adım 10, 2 resimden 2.
    • Remove the two Phillips #2 screws attaching the fuse to the grill.
    • Remove the fuse from the grill.
  11. George Foreman GR-20 Disassembly: adım 11, 1 resimden 1.
    • Remove the Phillips #2 screw from the white wire.
    • Remove the white wire from the grill.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Bir Yorum
Thanks to this, I've been able to fix my George Foreman grill! Absolute blessing!
OK GGS - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 18
Her zaman: 964
