Ana içeriğe geç
George Foreman Wire Repair
Neye ihtiyacın var
  1. George Foreman Wire Repair, George Foreman Wire Repair: adım 1, 1 resimden 1.
    • Make sure the appliance is unplugged and cooled off before beginning the repair.
    • If the appliance is still on, this could lead to safety hazards such as burning of the hand or electrocution.
    • Lights will appear lit if the appliance is still on so make sure the lights are not illuminated.
  2. George Foreman Wire Repair: adım 2, 1 resimden 1.
    • Open the appliance by lifting the top plate away from you.
  3. George Foreman Wire Repair: adım 3, 2 resimden 1. George Foreman Wire Repair: adım 3, 2 resimden 2.
    • Remove the plates by pushing down on the black knobs on either side of the plates, top and bottom.
    • After, pick up and lift the plates off of the appliance.
  4. George Foreman Wire Repair: adım 4, 3 resimden 1. George Foreman Wire Repair: adım 4, 3 resimden 2. George Foreman Wire Repair: adım 4, 3 resimden 3.
    • Underneath where the plates sit you will see a coil and 12 screws holding the base plate in place.
    • Remove the 12 Phillips head screws on the bottom plate with a #1 Phillips head screw driver.
  5. George Foreman Wire Repair: adım 5, 1 resimden 1.
    • After unscrewing the screws, lift off the base plate.
    • This is where you will see the wires.
  6. George Foreman Wire Repair: adım 6, 2 resimden 1. George Foreman Wire Repair: adım 6, 2 resimden 2.
    • Re-establish the disconnected or loose wires by pushing them back into the point of connection.
    • Push the wires into the connection center on the bottom of the plate until you can't anymore. This is how you know they will not come loose again.
    • Make sure to keep the wires separated so they do not touch and become tangled to avoid sparks and electrocution.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ali Sealby
163 İtibar
1 Kılavuz yazıldı
Bir Yorum
Unable to repair the split cord on my George Foreman small health fit grill model 25800 as the plates are screwed on. Please advise.
Ann Holdsworth - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 11
Son 30 gün: 48
Her zaman: 2,000
