Ana içeriğe geç
Giant Reign 2 Front Wheel Replacement
Neye ihtiyacın var
  1. Giant Reign 2 Front Wheel Replacement, Hex Screws: adım 1, 1 resimden 1.
    • Using the 4mm Allen wrench, partially unscrew the 4 (22mm) hex screws on the front of the axle casing to allow the axle to slide freely.
  2. Giant Reign 2 Front Wheel Replacement, Axle Screw: adım 2, 2 resimden 1. Giant Reign 2 Front Wheel Replacement, Axle Screw: adım 2, 2 resimden 2.
    • Using the 8mm Allen wrench, loosen the axle screw until 1/2 of the axle screw is visible.
    • Push the axle screw to reveal the axle rod on the other side.
  3. Giant Reign 2 Front Wheel Replacement: adım 3, 1 resimden 1.
    • Using the Allen wrench, finish unscrewing the axle screw and pull it out.
    • Hold the wheel when pulling out the axle rod so that the bike does not fall.
  4. Giant Reign 2 Front Wheel Replacement, Front Wheel: adım 4, 1 resimden 1.
    • Pull the wheel from the fork.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Andrew Krasts
302 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-14, Amido Fall 2012 Cal Poly, Team 9-14, Amido Fall 2012 üyesi
CPSU-AMIDO-F12S9G14
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 12
Son 7 gün: 44
Son 30 gün: 142
Her zaman: 12,920
