Ana içeriğe geç
Giant Reign 2 Headset Replacement
Neye ihtiyacın var
  1. Giant Reign 2 Headset Replacement, Hex Screws: adım 1, 1 resimden 1.
    • Using the 4mm Allen wrench, partially unscrew the 4 (22mm) hex screws on the front of the axle casing to allow the axle to slide freely.
    FixBot'a Sor
    Yorum Ekle
  2. Giant Reign 2 Headset Replacement, Axle Screw: adım 2, 2 resimden 1. Giant Reign 2 Headset Replacement, Axle Screw: adım 2, 2 resimden 2.
    • Using the 8mm Allen wrench, loosen the axle screw until 1/2 of the axle screw is visible.
    • Push the axle screw to reveal the axle rod on the other side.
    FixBot'a Sor
    Yorum Ekle
  3. Giant Reign 2 Headset Replacement: adım 3, 1 resimden 1.
    • Using the Allen wrench, finish unscrewing the axle screw and pull it out.
    • Hold the wheel when pulling out the axle rod so that the bike does not fall.
    FixBot'a Sor
    Yorum Ekle
  4. Giant Reign 2 Headset Replacement, Front Wheel: adım 4, 1 resimden 1.
    • Pull the wheel from the fork.
    FixBot'a Sor
    Yorum Ekle
  5. Giant Reign 2 Headset Replacement, Headset: adım 5, 2 resimden 1. Giant Reign 2 Headset Replacement, Headset: adım 5, 2 resimden 2.
    • Using the 8mm Allen wrench, unscrew 2 (32mm) screws to release the brake calipers from the fork.
    • If necessary use wire cutters to release zip ties attaching cables to the forks.
    FixBot'a Sor
    Yorum Ekle
  6. Giant Reign 2 Headset Replacement: adım 6, 3 resimden 1. Giant Reign 2 Headset Replacement: adım 6, 3 resimden 2. Giant Reign 2 Headset Replacement: adım 6, 3 resimden 3.
    • Using the 8mm Allen wrench, unscrew the 30mm head screw located on top of the steam.
    • Using the 4mm Allen wrench, loosen the side screw on both sides.
    • Lift off the handlebar.
    • Hang the handlebar gently from the cables. Do not pull the cables as you may damage the brake/derailleur lines.
    FixBot'a Sor
    Yorum Ekle
  7. Giant Reign 2 Headset Replacement: adım 7, 3 resimden 1. Giant Reign 2 Headset Replacement: adım 7, 3 resimden 2. Giant Reign 2 Headset Replacement: adım 7, 3 resimden 3.
    • Slide off the spacers.
    • Lift off the seal.
    FixBot'a Sor
    Yorum Ekle
  8. Giant Reign 2 Headset Replacement: adım 8, 1 resimden 1.
    • Slide the fork out of the casing.
    FixBot'a Sor
    Yorum Ekle
  9. Giant Reign 2 Headset Replacement: adım 9, 1 resimden 1.
    • Using your fingers, pry the bearings from the top and bottom of the headset.
    FixBot'a Sor
    Yorum Ekle
  10. Giant Reign 2 Headset Replacement: adım 10, 1 resimden 1.
    • Apply WD-40 to both ends of the headset and bearings.
    • Dry headset and bearings with paper towels.
    • Repeat as necessary until clean.
    FixBot'a Sor
    Yorum Ekle
  11. Giant Reign 2 Headset Replacement: adım 11, 2 resimden 1. Giant Reign 2 Headset Replacement: adım 11, 2 resimden 2.
    • Using your finger, apply all-purpose lube to the bearings and each end of the headset.
    • Insert the bearings into the headset with the beveled side facing into the headset.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Sterling Grande
148 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-14, Amido Fall 2012 Cal Poly, Team 9-14, Amido Fall 2012 üyesi
CPSU-AMIDO-F12S9G14
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 12
Son 30 gün: 43
Her zaman: 4,670
