Ana içeriğe geç
Giant Reign 2 Rear Shock Replacement
Neye ihtiyacın var
    1. Giant Reign 2 Rear Shock Replacement, Rear Shock: adım 1, 1 resimden 1.
      • Orient the bike upside down.
      FixBot'a Sor
      Yorum Ekle
    2. Giant Reign 2 Rear Shock Replacement: adım 2, 1 resimden 1.
      • Remove the 10mm screw and take the bash guard off of the frame.
      FixBot'a Sor
      Yorum Ekle
    3. Giant Reign 2 Rear Shock Replacement: adım 3, 1 resimden 1.
      • Remove the 65mm screw that connects the bottom of the shock to the frame.
      • Use a wrench to hold the other side.
      FixBot'a Sor
      Yorum Ekle
    4. Giant Reign 2 Rear Shock Replacement: adım 4, 1 resimden 1.
      • Remove the 40mm screw that connects the shock to the link arm of the suspension.
      FixBot'a Sor
      Yorum Ekle
    5. Giant Reign 2 Rear Shock Replacement: adım 5, 2 resimden 1. Giant Reign 2 Rear Shock Replacement: adım 5, 2 resimden 2.
      • Push the shock out of the brackets mounting it to the frame and suspension arm.
      • This may require some force and slight wiggling from side to side.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Andrew Krasts
302 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-14, Amido Fall 2012 Cal Poly, Team 9-14, Amido Fall 2012 üyesi
CPSU-AMIDO-F12S9G14
4 Üyeler
10 adet Kılavuz yazıldı
1Rehber Yorum
Which valve stem is the one to put air into the shock there's one on the bottom one on top and adjustment knob right next to the top one
Ron Hobson - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 16
Son 30 gün: 47
Her zaman: 5,747
