Ana içeriğe geç
Giant Reign 2 Tube Replacement
Neye ihtiyacın var
  1. Giant Reign 2 Tube Replacement, Hex Screws: adım 1, 1 resimden 1.
    • Using the 4mm Allen wrench, partially unscrew the 4 (22mm) hex screws on the front of the axle casing to allow the axle to slide freely.
  2. Giant Reign 2 Tube Replacement, Axle Screw: adım 2, 2 resimden 1. Giant Reign 2 Tube Replacement, Axle Screw: adım 2, 2 resimden 2.
    • Using the 8mm Allen wrench, loosen the axle screw until 1/2 of the axle screw is visible.
    • Push the axle screw to reveal the axle rod on the other side.
  3. Giant Reign 2 Tube Replacement: adım 3, 1 resimden 1.
    • Using the Allen wrench, finish unscrewing the axle screw and pull it out.
    • Hold the wheel when pulling out the axle rod so that the bike does not fall.
  4. Giant Reign 2 Tube Replacement, Front Wheel: adım 4, 1 resimden 1.
    • Pull the wheel from the fork.
  5. Giant Reign 2 Tube Replacement, Tube: adım 5, 1 resimden 1.
    • Look at your tire and determine the correct tube size by locating the number (formated ## x #.##) on the wall of the tire.
    • Bike tubes come with one of two standard valve types: presta and schrader. These guides show the installation of a tube with a presta valve.
  6. Giant Reign 2 Tube Replacement: adım 6, 3 resimden 1. Giant Reign 2 Tube Replacement: adım 6, 3 resimden 2. Giant Reign 2 Tube Replacement: adım 6, 3 resimden 3.
    • Unscrew the cap covering the valve.
    • Remove the spacer that holds the valve in place against the rim of the wheel.
    • Open the valve by turning the nut and pressing the valve in to release air pressure from the tube.
  7. Giant Reign 2 Tube Replacement: adım 7, 3 resimden 1. Giant Reign 2 Tube Replacement: adım 7, 3 resimden 2. Giant Reign 2 Tube Replacement: adım 7, 3 resimden 3.
    • Slide the tire lever between the tire and the rim.
    • Push down on the tire lever until the edge of the tire is higher than the edge of the rim.
    • Insert a second tire lever adjacent to the first.
    • Slowly work one tire lever around the rim until the whole tire is loose.
  8. Giant Reign 2 Tube Replacement: adım 8, 2 resimden 1. Giant Reign 2 Tube Replacement: adım 8, 2 resimden 2.
    • Press the valve through the rim of the wheel.
    • Remove the tube from the tire.
  9. Giant Reign 2 Tube Replacement: adım 9, 1 resimden 1.
    • Partially inflate the tube.
  10. Giant Reign 2 Tube Replacement: adım 10, 2 resimden 1. Giant Reign 2 Tube Replacement: adım 10, 2 resimden 2.
    • Push the valve through the rim.
    • Push the tube into the tire all the way around the rim of the wheel.
  11. Giant Reign 2 Tube Replacement: adım 11, 1 resimden 1.
    • Push the bead of the tire back into place around the rim.
    • Make sure not to pinch the tube between the bead of the tire and the rim. Failure to do so may cause a pinch flat.
  12. Giant Reign 2 Tube Replacement: adım 12, 1 resimden 1.
    • Inflate the tube to the desired air pressure.
    • A suggested range of air pressure is located on the wall of the tire (formatted ##-##psi).
  13. Giant Reign 2 Tube Replacement: adım 13, 2 resimden 1. Giant Reign 2 Tube Replacement: adım 13, 2 resimden 2.
    • Close the valve and replace the cap.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
Sterling Grande
148 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-14, Amido Fall 2012 Cal Poly, Team 9-14, Amido Fall 2012 üyesi
CPSU-AMIDO-F12S9G14
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 14
Her zaman: 2,968
