Ana içeriğe geç
Giant Talon 29er Chainring Replacement
Neye ihtiyacın var
  1. Giant Talon 29er Chainring Replacement, Chainring: adım 1, 3 resimden 1. Giant Talon 29er Chainring Replacement, Chainring: adım 1, 3 resimden 2. Giant Talon 29er Chainring Replacement, Chainring: adım 1, 3 resimden 3.
    • Push the chain tensioner towards the front of the bicycle to release the tension on the chain.
    • Unroute the chain from the chainrings.
  2. Giant Talon 29er Chainring Replacement: adım 2, 1 resimden 1.
    • Remove the 8 mm Hex screw from the crank arm.
  3. Giant Talon 29er Chainring Replacement: adım 3, 1 resimden 1.
    • Remove the crank arm and chainrings by pulling the crank arm away from the bicycle frame.
  4. Giant Talon 29er Chainring Replacement: adım 4, 1 resimden 1.
    • Remove the four 5 mm Hex screws that mount the crank arm to the chainrings.
  5. Giant Talon 29er Chainring Replacement: adım 5, 3 resimden 1. Giant Talon 29er Chainring Replacement: adım 5, 3 resimden 2. Giant Talon 29er Chainring Replacement: adım 5, 3 resimden 3.
    • Rotate the largest chainring 45 degrees in either direction.
    • Remove the crank arm from the chainrings.
Sonuç
Reassemble your bicycle with the new chainrings by following these instructions in reverse order.
Bir başkası bu kılavuzu tamamladı.
Ben Frisbie
209 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 3,413
