Giriş
You just need:
> 1 screwdriver Tors TR6
> 1 screwdriver Philips classical Cross little
> courage and bravery :)
Aletler
Parçalar
Hiçbir parça belirtilmedi.
With Torx T6, you can remove the 13 screws. Follow their emplacement because 3 of them are taller (orange on picture 2)
Using plastic tools, you can start unclipping the hood from the front of the machine. Insert one opening tool and insert a second. Slide the tools around to pop off the bottom of the laptop.
Do not unclip the back face fully; only the front and the two sides. You can nevertheless detach the 4 corners.
Remove the hood starting at the front two corners. Lift up at those corners.
To reassemble, follow these steps in reverse order.
Bu çevirmenlere özel teşekkürler:
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
