Ana içeriğe geç
Gigabyte P34G Battery Replacement
Neye ihtiyacın var
  1. Gigabyte P34G Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Remove all 15 screws on the underside of the laptop using a Phillips #0 screwdriver.
    • There are three different sized screws.
    • x1 9.8mm Screw
    • x8 5.6mm Screws
    • x6 5.0mm Screws
    FixBot'a Sor
    Yorum Ekle
  2. Gigabyte P34G Battery Replacement: adım 2, 1 resimden 1.
    • Remove the four 4.5 mm screws using a Phillips #0 screwdriver.
    • Save the screws in a safe place for reassembly later.
    FixBot'a Sor
    Yorum Ekle
  3. Gigabyte P34G Battery Replacement: adım 3, 1 resimden 1.
    • Pull the wires down towards yourself to gently detach the connector from the main drive.
    • Save connector for reassembly later.
    FixBot'a Sor
    Yorum Ekle
  4. Gigabyte P34G Battery Replacement: adım 4, 1 resimden 1.
    • Carefully lift the battery for removal and discard properly.
    • Replace with new battery.
    FixBot'a Sor
    Yorum Ekle
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
yeunghayden
841 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-1, Regan Spring 2015 Cal Poly, Team 8-1, Regan Spring 2015 üyesi
CPSU-REGAN-S15S8G1
5 Üyeler
12 adet Kılavuz yazıldı
12Kılavuz Yorumları
Does anyone know where to find a replacement, or if you can fit the version 1 of this computer with a larger capacity battery from version 2?
tadej rezar - Yanıt Paylaş
Over at https://www.mysn.de/detail.asp?bestellnr... (don't mind their stock picture), they still sell the battery for the C404 (which is identical to the P34G v2). I just bought a new 61.25 Wh GNC-J40, manufactured in 2016/07.
M D - Yanıt Paylaş
Will it run without the battery or is it a required part of the circuit? I have a P35G V2 and I only use it plugged in anyway.
jens_lipponer - Yanıt Paylaş
The battery in my P34G v2 is pretty solidly stuck to the chassis. I don't really want to pull on it too hard but is this normal?
Donald Macaulay - Yanıt Paylaş
@jens_lipponer Yes it runs without the battery fine. I have my battery disconnected as it is really swolen and the laptop boots without a problem.
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 44
Her zaman: 20,404
