Ana içeriğe geç
Gigabyte P34G Solid State Drive Replacement
Neye ihtiyacın var
  1. Gigabyte P34G Solid State Drive Replacement, Solid State Drive: adım 1, 1 resimden 1.
    • Remove all 15 marked screws on the underside of the laptop using a #0 screwdriver.
    • There are three different sized screws.
    • x1 9.8mm Screw
    • x8 5.6mm Screws
    • x6 5.0mm Screws
    • Divide the screws by size and save them in a safe space for reassembly later.
    FixBot'a Sor
    Yorum Ekle
  2. Gigabyte P34G Solid State Drive Replacement: adım 2, 1 resimden 1.
    • Unscrew the marked 4.5mm screw with a #0 screwdriver.
    • Set the screw aside to use for reassembly after replacing the solid state drive.
    FixBot'a Sor
    Yorum Ekle
  3. Gigabyte P34G Solid State Drive Replacement: adım 3, 1 resimden 1.
    • Carefully pull the solid state drive in the direction shown to disconnect it from the port.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
yeunghayden
841 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-1, Regan Spring 2015 Cal Poly, Team 8-1, Regan Spring 2015 üyesi
CPSU-REGAN-S15S8G1
5 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 7
Son 30 gün: 19
Her zaman: 2,103
