Ana içeriğe geç
Gigabyte Radeon HD 3870 GPU Thermal Paste and Fan Cleaning
Neye ihtiyacın var
  1. Gigabyte Radeon HD 3870 GPU Thermal Paste and Fan Cleaning, Removing the heatsink.: adım 1, 3 resimden 1. Gigabyte Radeon HD 3870 GPU Thermal Paste and Fan Cleaning, Removing the heatsink.: adım 1, 3 resimden 2. Gigabyte Radeon HD 3870 GPU Thermal Paste and Fan Cleaning, Removing the heatsink.: adım 1, 3 resimden 3.
    • Remove the 4 screws that hold the heatsink bracket in place. Be sure not to lose any screws or springs during disassembly.
    • Disconnect the fan.
    • Clean the old thermal paste both from the cooler and the die. It is best to use isopropyl alcohol and cotton swabs or paper towel, but be careful not to go too hard on the die.
  2. Gigabyte Radeon HD 3870 GPU Thermal Paste and Fan Cleaning, Cleaning the fan.: adım 2, 3 resimden 1. Gigabyte Radeon HD 3870 GPU Thermal Paste and Fan Cleaning, Cleaning the fan.: adım 2, 3 resimden 2. Gigabyte Radeon HD 3870 GPU Thermal Paste and Fan Cleaning, Cleaning the fan.: adım 2, 3 resimden 3.
    • Remove the 11 screws that hold the assembly together.
    • Use a soft brush or compressed air to clean the heatsink fins and fan.
    • My fan was making a grinding noise so I unpealed it`s back sticker carefully and used just a tiny drop of sewing machine oil from a needle to fix it. Then reapplied the sticker to keep dust out.
    • When putting back the cooling assembly, do NOT tighten the screws a lot, because the base is made of plastic and will break.
  3. Gigabyte Radeon HD 3870 GPU Thermal Paste and Fan Cleaning, Applying new thermal paste.: adım 3, 1 resimden 1.
    • Don`t use too much thermal paste, just enough to cover some portion of the pad. If you have a spreader, use it. The thermal paste will apply evenly after you tighten the heatsink bracket.
    • Last, put the heatsink back carefully and tighten the screws in a criss cross pattern to ensure even pressure. Dont forget to plug in the fan cable.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Simeon Brankov
7.145 İtibar
54 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 231
