Ana içeriğe geç
Giriş
This guide demonstrates:
1. How to disassemble the Gipo H369e.
2. What tools to use in the disassembly.
  • Phillips head 000 screwdriver
  • Small prying tool (ex: puddy knife)
  • Needle nose tweezers
3. How to replace the keypad.
  1. Insert thumb into the groove on the back lefthand corner of the phone to unsnap the back cover. Insert thumb into the groove on the back lefthand corner of the phone to unsnap the back cover.
    • Insert thumb into the groove on the back lefthand corner of the phone to unsnap the back cover.
  2. Remove the battery from the back of the phone.
    • Remove the battery from the back of the phone.
  3. MacBook Pil Tamir Setleri
    Başlangıç $69.99
    Buy Now
    Başlangıç $69.99
    Buy Now
  4. Unscrew the 5 screws on the back of the phone using the Philips Head 000 screwdriver. Unscrew the 5 screws on the back of the phone using the Philips Head 000 screwdriver.
    • Unscrew the 5 screws on the back of the phone using the Philips Head 000 screwdriver.
  5. Use the plastic opening tool to pry the front of the phone away from the back of the phone. Use the plastic opening tool to pry the front of the phone away from the back of the phone. Use the plastic opening tool to pry the front of the phone away from the back of the phone.
    • Use the plastic opening tool to pry the front of the phone away from the back of the phone.
  6. Once the front and back of the phone are separated, the keypad will fall out. You can now replace your old keypad. Once the front and back of the phone are separated, the keypad will fall out. You can now replace your old keypad.
    • Once the front and back of the phone are separated, the keypad will fall out. You can now replace your old keypad.
    • Use the needle nose pliers to peel the plastic screen away from the front of the disassembled phone. You can now replace the plastic screen.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Janelle Norris
161 İtibar
2 adet Kılavuz yazıldı
Takım
Ohio State, Team 1-4, Garvin Fall 2015 Ohio State, Team 1-4, Garvin Fall 2015 üyesi
OSU-GARVIN-F15S1G4
3 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 1
Her zaman: 132
