Giriş
Troubleshooting and replacing plastic gear in a Glade Automatic Spray Holder SJC-180. The gears for this device is 1 fan shape, 1 round one attached to the motor, and 2 round ones. They can slip off of connecting gear or be broken. This guide will help you determine the problem and fix it.
Neye ihtiyacın var
Press the button labelled glade to open the housing.
Locate the timer switch and slide it to off.
Use small needle nose pliers to gently remove each terminal. Check if any wires are disconnected or loose.
The terminals with negative connections (black wires) could have breaks or might have detached from the terminal base. Check for additional issues.
The bottom terminal is one piece instead of two pieces like the top ones.
Pull off the plastic gear cover. Be careful of the wires because they could be stuck to the plastic cover.
Pull upward on the circuit board. The circuit board is held in place by three pegs and the board is not attached to the gears.
Using only your fingers, remove each gear. Start with the fan shaped gear. Once removed, inspect each gear for breaks or other issues. Make sure to check the edge teeth and center teeth of each gear. Any gear that is damaged must be replaced.
Remove the second and largest gear.
Remove the slightly smaller third gear. This will expose a small gear that is attached to the motor.
Do not remove the small gear that is attached to the motor. Inspect the small gear for any damage. Do not remove the motor.
