Ana içeriğe geç
Glass Door Latch Replacement
Neye ihtiyacın var
  1. Glass Door Latch Replacement, Outer Removal: adım 1, 3 resimden 1. Glass Door Latch Replacement, Outer Removal: adım 1, 3 resimden 2. Glass Door Latch Replacement, Outer Removal: adım 1, 3 resimden 3.
    • Using a Phillips #3 screwdriver, unscrew the two 50mm screws on the inner and outer handles.
    • Remove the handles.
  2. Glass Door Latch Replacement, Preparation: adım 2, 3 resimden 1. Glass Door Latch Replacement, Preparation: adım 2, 3 resimden 2. Glass Door Latch Replacement, Preparation: adım 2, 3 resimden 3.
    • Using the latch key, make sure the key is pointed in the downward position.
    • Insert the second screwdriver or dowel into the bottom hole or latch key hole to prevent the mechanism from falling.
    • The latch mechanism can fall down into the door if the screwdriver/dowel is not inserted.
  3. Glass Door Latch Replacement: adım 3, 2 resimden 1. Glass Door Latch Replacement: adım 3, 2 resimden 2.
    • Using a Phillips #3 screwdriver, remove the two 13mm screws from the door while holding the latch.
    • Make sure to hold the latch while unscrewing the mechanism from the door.
  4. Glass Door Latch Replacement, Mechanism Removal: adım 4, 2 resimden 1. Glass Door Latch Replacement, Mechanism Removal: adım 4, 2 resimden 2.
    • While holding the latch, move the mechanism downwards and remove it from the door.
  5. Glass Door Latch Replacement, Replacement Prep: adım 5, 2 resimden 1. Glass Door Latch Replacement, Replacement Prep: adım 5, 2 resimden 2.
    • Using the latch key, put the latch in the lock position.
    • While the mechanism can be installed without the latch being out. Using the latch as a handle will help the installation.
  6. Glass Door Latch Replacement, Installation: adım 6, 3 resimden 1. Glass Door Latch Replacement, Installation: adım 6, 3 resimden 2. Glass Door Latch Replacement, Installation: adım 6, 3 resimden 3.
    • Insert the mechanism top first while holding the latch.
    • Do not let go of the latch until completing Step 7.
  7. Glass Door Latch Replacement, Installation Cont.: adım 7, 3 resimden 1. Glass Door Latch Replacement, Installation Cont.: adım 7, 3 resimden 2. Glass Door Latch Replacement, Installation Cont.: adım 7, 3 resimden 3.
    • Using a Phillips #3 screwdriver, screw in the two 13mm screws in the original holes.
    • Remove the screwdriver or dowel from the hole once the mechanism is screwed into the door.
  8. Glass Door Latch Replacement, Latch Correction: adım 8, 2 resimden 1. Glass Door Latch Replacement, Latch Correction: adım 8, 2 resimden 2.
    • Insert the latch key back into the keyhole.
    • Move the latch key back into the unlocked position.
  9. Glass Door Latch Replacement, Handle Placement: adım 9, 3 resimden 1. Glass Door Latch Replacement, Handle Placement: adım 9, 3 resimden 2. Glass Door Latch Replacement, Handle Placement: adım 9, 3 resimden 3.
    • Place the handles back into place and screw in the two 50mm screws with a Phillips #3 screwdriver.
    • Make sure the outer and inner handles are aligned. Nothing's worse than a misaligned door handle!
Sonuç
Bir başkası bu kılavuzu tamamladı.
CJ Cummings
193 İtibar
1 Kılavuz yazıldı
Ekip
3Kılavuz Yorumları
Thank you for sharing this. Btw here is a detailed guide on how to mortise a door latch. In addition to enhancing your practical skills, learning how to mortise a door latch can help you avoid paying a high locksmith fee.
Revolar Revolar - Yanıt
what brand or manufacturer is this door/lock assembly. im trying to find keyed trim for this
yaakov danzig - Yanıt
Thank you so much for this post. I was a little nervous about replacing my sliding door lock. Your step by step instructions with pictures made the replacement of my lock so easy.
Dawn - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 19
Son 30 gün: 77
Her zaman: 7,678
