Giriş
This guide shows you how to change the light bulb in a globe.
With a plastic meridian like this one, you need to raise the meridian slightly from the North Pole. Use the plastic ring on the north pole to gently press the globe down and pull up the meridian so you lift the little pin,which holdes the globe.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
