Giriş
If you can't figure out how to use your GoPro, chances are you either need to read the manual or the LCD is broken. In the case of the latter, this guide will help you install a new display.
Neye ihtiyacın var
Place your thumb on the indentation in the back case on the side of the GoPro.
Gently press down with your thumb and lift the back cover away from the case to remove it.
Slide a plastic opening tool between the battery and the rear case.
Gently pry the battery up and out of the rear case.
Remove the four Phillips #00 screws securing the rear case to the rest of the device:
Two 5.5 mm coarse thread screws.
Two 4.4 mm fine thread screws.
Bu adımda kullanılan alet:Tweezers$4.99
Using a plastic opening tool or your fingernail, flip up the locking tab on the SD board ribbon cable ZIF connector on the motherboard assembly.
Use a pair of tweezers to remove the SD board ribbon cable from its connector on the motherboard.
Lift the speaker out of the rear case with the tip of a spudger.
Remove the rear case.
Hello. GoPro HERO2 there. overheating after doing update. 10-15 minutes after closing. overheating.
You can try put some new heat sink compound under that silver big element (radiator) that you see in step 9 (simply remove 2 screws holding it).
hellfire -
Remove the three screws securing the motherboard assembly to the front case:
Two 10.8 mm Phillips #00 screws.
One 4.8 mm Phillips #00 screw.
Gently wedge a plastic opening tool underneath the foam padding on top of the LCD ribbon cable.
Pry the foam padding up until the LCD ribbon cable can be lifted off the surface of the motherboard.
Once its ribbon cable is free, remove the LCD from the motherboard assembly.
5 farklı kişi bu kılavuzu tamamladı.
13 Yorum
Where do you purchase the replacement lcd?
hero2 lcd led replacement part available here
dennis -
I'm also looking for an LCD replacekit. Unfortionally I broken the front LCD of a GoPro Here 3 cam.
Where can I get one?
RageCams has it here:
dennis -
Im also in need of a LCD for my GoPro Here 3+
is there anyone who can help me and the other 2 guys ?!!
I ve just a reference (VPP XEN FKJ06018-01 1142) of the LCD but i m not abble to find the item... Someone can help us?
RageCams has all the gopro replacement parts:
dennis -
Any find where to get the replacement LCDs from? (Required for gopro 2)?
RageCams has it
dennis -
Found Gopro parts in aliexpress
I bought a lcd front display (mine was broken) and replace, now it works perfect!! (it took me 1 year+ to find it)
RageCams also has all the parts available
dennis -
hero2 lcd led replacement part available here:
