Ana içeriğe geç
GoPro HD Hero2 Motherboard Assembly Replacement
Neye ihtiyacın var
  1. GoPro HD Hero2 Motherboard Assembly Replacement, Back Cover: adım 1, 2 resimden 1. GoPro HD Hero2 Motherboard Assembly Replacement, Back Cover: adım 1, 2 resimden 2.
    • Place your thumb on the indentation in the back case on the side of the GoPro.
    • Gently press down with your thumb and lift the back cover away from the case to remove it.
  2. GoPro HD Hero2 Motherboard Assembly Replacement, Battery: adım 2, 2 resimden 1. GoPro HD Hero2 Motherboard Assembly Replacement, Battery: adım 2, 2 resimden 2.
    • Slide a plastic opening tool between the battery and the rear case.
    • Gently pry the battery up and out of the rear case.
  3. GoPro HD Hero2 Motherboard Assembly Replacement: adım 3, 1 resimden 1.
    • Remove the battery from the case.
  4. GoPro HD Hero2 Motherboard Assembly Replacement, Rear Case: adım 4, 1 resimden 1.
    • Remove the four Phillips #00 screws securing the rear case to the rest of the device:
    • Two 5.5 mm coarse thread screws.
    • Two 4.4 mm fine thread screws.
  5. GoPro HD Hero2 Motherboard Assembly Replacement: adım 5, 2 resimden 1. GoPro HD Hero2 Motherboard Assembly Replacement: adım 5, 2 resimden 2.
    • Slide the edge of a plastic opening tool underneath the sticker on the rear cover and gently peel the sticker up.
    • Once you have enough of the sticker peeled up with the plastic opening tool, grab an edge of it with your fingers and pull it off completely.
  6. GoPro HD Hero2 Motherboard Assembly Replacement: adım 6, 2 resimden 1. GoPro HD Hero2 Motherboard Assembly Replacement: adım 6, 2 resimden 2.
    • Grasp the rear case and lift it off of the front case.
    • Do not try to completely remove the rear case yet, as it is still attached by the display port ribbon cable.
  7. GoPro HD Hero2 Motherboard Assembly Replacement: adım 7, 2 resimden 1. GoPro HD Hero2 Motherboard Assembly Replacement: adım 7, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Using a plastic opening tool or your fingernail, flip up the locking tab on the SD board ribbon cable ZIF connector on the motherboard assembly.
    • Be careful that you are prying on the locking tab, and not the connector itself.
    • Use a pair of tweezers to remove the SD board ribbon cable from its connector on the motherboard.
    Hallo, ich fürchte bei mir ist das obere Flexkabel defekt.(oben mittig, welches nach hinten weg geht) Gibt es da ersatz oder reperaturen?
    moejoe DO - Yanıt
  8. GoPro HD Hero2 Motherboard Assembly Replacement: adım 8, 3 resimden 1. GoPro HD Hero2 Motherboard Assembly Replacement: adım 8, 3 resimden 2. GoPro HD Hero2 Motherboard Assembly Replacement: adım 8, 3 resimden 3.
    • Lift the speaker out of the rear case with the tip of a spudger.
    • Remove the rear case.
    It's not a speaker it the microphone and the wire is very fragile.
    Matt c - Yanıt
    Hello. GoPro HERO2 there. overheating after doing update. 10-15 minutes after closing. overheating.
    coskunadnan - Yanıt
    You can try put some new heat sink compound under that silver big element (radiator) that you see in step 9 (simply remove 2 screws holding it).
    hellfire -
  9. GoPro HD Hero2 Motherboard Assembly Replacement, Motherboard Assembly: adım 9, 1 resimden 1.
    • Remove the three screws securing the motherboard assembly to the front case:
    • Two 10.8 mm Phillips #00 screws.
    • One 4.8 mm Phillips #00 screw.
  10. GoPro HD Hero2 Motherboard Assembly Replacement: adım 10, 2 resimden 1. GoPro HD Hero2 Motherboard Assembly Replacement: adım 10, 2 resimden 2.
    • Gently grab the edges of the motherboard assembly and lift it out of the front case.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
David Hodson
152.760 İtibar
127 adet Kılavuz yazıldı
2Kılavuz Yorumları
Where exactly do you buy the replacement boards? I cant find them anywhere..
Lauren Ashleyy - Yanıt
coskunadnan - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 17
Her zaman: 18,553
