Ana içeriğe geç
GoPro HD Hero2 Rear Case Replacement
Salt Önkoşul
Bu kılavuz yalnızca diğer kılavuzlar için bir ön koşul olarak kullanılmak üzere tasarlanmıştır. Tek başına eksiktir.
Neye ihtiyacın var
  1. GoPro HD Hero2 Rear Case Replacement, Rear Case: adım 1, 1 resimden 1.
    • Remove the four Phillips #00 screws securing the rear case to the rest of the device:
    • Two 5.5 mm coarse thread screws.
    • Two 4.4 mm fine thread screws.
  2. GoPro HD Hero2 Rear Case Replacement: adım 2, 2 resimden 1. GoPro HD Hero2 Rear Case Replacement: adım 2, 2 resimden 2.
    • Slide the edge of a plastic opening tool underneath the sticker on the rear cover and gently peel the sticker up.
    • Once you have enough of the sticker peeled up with the plastic opening tool, grab an edge of it with your fingers and pull it off completely.
  3. GoPro HD Hero2 Rear Case Replacement: adım 3, 2 resimden 1. GoPro HD Hero2 Rear Case Replacement: adım 3, 2 resimden 2.
    • Grasp the rear case and lift it off of the front case.
    • Do not try to completely remove the rear case yet, as it is still attached by the display port ribbon cable.
  4. GoPro HD Hero2 Rear Case Replacement: adım 4, 2 resimden 1. GoPro HD Hero2 Rear Case Replacement: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Using a plastic opening tool or your fingernail, flip up the locking tab on the SD board ribbon cable ZIF connector on the motherboard assembly.
    • Be careful that you are prying on the locking tab, and not the connector itself.
    • Use a pair of tweezers to remove the SD board ribbon cable from its connector on the motherboard.
  5. GoPro HD Hero2 Rear Case Replacement: adım 5, 3 resimden 1. GoPro HD Hero2 Rear Case Replacement: adım 5, 3 resimden 2. GoPro HD Hero2 Rear Case Replacement: adım 5, 3 resimden 3.
    • Lift the speaker out of the rear case with the tip of a spudger.
    • Remove the rear case.
Sonuç
David Hodson
152.778 İtibar
127 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 771
