Ana içeriğe geç
GoPro Hero+ LCD Battery Replacement
Neye ihtiyacın var
  1. GoPro Hero+ LCD Battery Replacement, Back Panel: adım 1, 2 resimden 1. GoPro Hero+ LCD Battery Replacement, Back Panel: adım 1, 2 resimden 2.
    • Be sure to power off the GoPro before you start disassembly.
    • Pop up and pull back on the clip to remove the screen cover and expose the back panel with the touchscreen.
    FixBot'a Sor
    Yorum Ekle
  2. GoPro Hero+ LCD Battery Replacement: adım 2, 2 resimden 1. GoPro Hero+ LCD Battery Replacement: adım 2, 2 resimden 2.
    • Use the metal spudger to pry around the perimeter of the panel.
    • Pry the panel upwards by inserting the metal spudger into the corner crease between the panel and camera shell.
    FixBot'a Sor
    Yorum Ekle
  3. GoPro Hero+ LCD Battery Replacement: adım 3, 2 resimden 1. GoPro Hero+ LCD Battery Replacement: adım 3, 2 resimden 2.
    • Pry around the panel to ensure it is not attached to the device.
    • Move the panel to the side so you can access the internal components.
    • The panel is still attached to the rest of the device with a ribbon cable, so be sure to not tear or damage the cable.
    FixBot'a Sor
    Yorum Ekle
  4. GoPro Hero+ LCD Battery Replacement, Battery: adım 4, 1 resimden 1.
    • Peel back the rear panel ribbon cable that is adhered to the battery until it is completely separated from the battery.
    • Be careful of metal contacts on strip; they can be sharp.
    FixBot'a Sor
    Yorum Ekle
  5. GoPro Hero+ LCD Battery Replacement: adım 5, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Using tweezers, peel off the copper tape on the right side of the battery.
    FixBot'a Sor
    Yorum Ekle
  6. GoPro Hero+ LCD Battery Replacement: adım 6, 2 resimden 1. GoPro Hero+ LCD Battery Replacement: adım 6, 2 resimden 2.
    • Place the plastic opening tool at one of the edges of the battery then pry until the battery is removed from the GoPro.
    FixBot'a Sor
    Yorum Ekle
  7. GoPro Hero+ LCD Battery Replacement: adım 7, 1 resimden 1.
    • Use a pair of tweezers to disconnect the battery connector from the motherboard.
    • Gently pull the battery off the motherboard. Pulling vertically off the motherboard will give a clean release.
    FixBot'a Sor
    Yorum Ekle
Sonuç
19 farklı kişi bu kılavuzu tamamladı.
Kyle
219 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 2-4, Blackwell Fall 2015 USF Tampa, Team 2-4, Blackwell Fall 2015 üyesi
USFT-BLACKWELL-F15S2G4
4 Üyeler
20 adet Kılavuz yazıldı
13Kılavuz Yorumları
This is a superb guide but where can one buy a replacement battery? I have looked on the web for the one in your photo but can't find a specific one.
I want to buy one of these cameras but would like to know I can replace the battery.
Thanks.
Andrew - Yanıt Paylaş
I am also trying to find the replacement battery for a Hero+. Have found a lot of batteries for all other versions of Gopro cams, but not one single one for a Hero+.
I have also sent an email to Gopro to get help. I am not prepared for an answer but I really would like to get hold of a battery.
Does anyone know how to get one?
Please contact me: rhafsrhafs@gmail.com. Rikard from Sweden.
Thanks
Rikard
Rikard Hård - Yanıt Paylaş
hi, do you know where i can get the housing for the gopro hero+ lcd. mine is broken and need a new one but can't find it anywhere...........
chris
christianrisan - Yanıt Paylaş
not even amazon?
Mary D'Alesandro - Yanıt Paylaş
this is awesome thanks a lot! , i dont want to be rude, but the title says battery replacementnt , why isnt anyone preparing a battery and putting it back in?, All everyone is doing is taking th battery out
John misquita - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 82
Son 30 gün: 235
Her zaman: 42,326
