Ana içeriğe geç
GoPro Hero+ LCD Lens Replacement
Neye ihtiyacın var
  1. GoPro Hero+ LCD Lens Replacement, Back Panel: adım 1, 2 resimden 1. GoPro Hero+ LCD Lens Replacement, Back Panel: adım 1, 2 resimden 2.
    • Be sure to power off the GoPro before you start disassembly.
    • Pop up and pull back on the clip to remove the screen cover and expose the back panel with the touchscreen.
    FixBot'a Sor
    Yorum Ekle
  2. GoPro Hero+ LCD Lens Replacement: adım 2, 2 resimden 1. GoPro Hero+ LCD Lens Replacement: adım 2, 2 resimden 2.
    • Use the metal spudger to pry around the perimeter of the panel.
    • Pry the panel upwards by inserting the metal spudger into the corner crease between the panel and camera shell.
    FixBot'a Sor
    Yorum Ekle
  3. GoPro Hero+ LCD Lens Replacement: adım 3, 2 resimden 1. GoPro Hero+ LCD Lens Replacement: adım 3, 2 resimden 2.
    • Pry around the panel to ensure it is not attached to the device.
    • Move the panel to the side so you can access the internal components.
    • The panel is still attached to the rest of the device with a ribbon cable, so be sure to not tear or damage the cable.
    FixBot'a Sor
    Yorum Ekle
  4. GoPro Hero+ LCD Lens Replacement, Battery: adım 4, 1 resimden 1.
    • Peel back the rear panel ribbon cable that is adhered to the battery until it is completely separated from the battery.
    • Be careful of metal contacts on strip; they can be sharp.
    FixBot'a Sor
    Yorum Ekle
  5. GoPro Hero+ LCD Lens Replacement: adım 5, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Using tweezers, peel off the copper tape on the right side of the battery.
    FixBot'a Sor
    Yorum Ekle
  6. GoPro Hero+ LCD Lens Replacement: adım 6, 2 resimden 1. GoPro Hero+ LCD Lens Replacement: adım 6, 2 resimden 2.
    • Place the plastic opening tool at one of the edges of the battery then pry until the battery is removed from the GoPro.
    FixBot'a Sor
    Yorum Ekle
  7. GoPro Hero+ LCD Lens Replacement: adım 7, 1 resimden 1.
    • Use a pair of tweezers to disconnect the battery connector from the motherboard.
    • Gently pull the battery off the motherboard. Pulling vertically off the motherboard will give a clean release.
    FixBot'a Sor
    Yorum Ekle
  8. GoPro Hero+ LCD Lens Replacement, MicroSD/Micro USB Port Assembly: adım 8, 3 resimden 1. GoPro Hero+ LCD Lens Replacement, MicroSD/Micro USB Port Assembly: adım 8, 3 resimden 2. GoPro Hero+ LCD Lens Replacement, MicroSD/Micro USB Port Assembly: adım 8, 3 resimden 3.
    • Remove the two 6 mm Phillips #00 screws.
    • Remove the single 4 mm Phillips #000 screws.
    FixBot'a Sor
    Yorum Ekle
  9. GoPro Hero+ LCD Lens Replacement: adım 9, 1 resimden 1.
    • Remove the image sensor from the camera.
    • You do not have to unplug the black box to remove the USB/SD chip.
    FixBot'a Sor
    Yorum Ekle
  10. GoPro Hero+ LCD Lens Replacement: adım 10, 1 resimden 1.
    • Grab the edge of the ribbon cable with the tweezers and gently pull until the cable is disconnected from the motherboard.
    • Be careful when removing the ribbon cable. You must pull gently or you can rip the ribbon off of its contacts.
    FixBot'a Sor
    Yorum Ekle
  11. GoPro Hero+ LCD Lens Replacement: adım 11, 1 resimden 1.
    • Gently lift the microSD/Micro USB assembly up and out of the device.
    FixBot'a Sor
    Yorum Ekle
  12. GoPro Hero+ LCD Lens Replacement, Image Sensor: adım 12, 1 resimden 1.
    • Use your fingers and gently pull out the sensor from the motherboard by slowly and gradually pulling up on the image sensor box.
    • Do not yank on the image sensor, it can rip out the wiring or damage the motherboard.
    FixBot'a Sor
    Yorum Ekle
  13. GoPro Hero+ LCD Lens Replacement, Motherboard: adım 13, 3 resimden 1. GoPro Hero+ LCD Lens Replacement, Motherboard: adım 13, 3 resimden 2. GoPro Hero+ LCD Lens Replacement, Motherboard: adım 13, 3 resimden 3.
    • Remove the three 4 mm Phillips #000 screws securing the motherboard.
    FixBot'a Sor
    Yorum Ekle
  14. GoPro Hero+ LCD Lens Replacement: adım 14, 1 resimden 1.
    • Use your fingers to gently remove the ribbon connected to the lens.
    • Be careful when removing the ribbon cable. Pull off gently or you can separate the ribbon from the contacts.
    FixBot'a Sor
    Yorum Ekle
  15. GoPro Hero+ LCD Lens Replacement: adım 15, 3 resimden 1. GoPro Hero+ LCD Lens Replacement: adım 15, 3 resimden 2. GoPro Hero+ LCD Lens Replacement: adım 15, 3 resimden 3.
    • Use your fingers and carefully pull out the motherboard from under the lens. It may take a little bit of adjusting to get it out.
    FixBot'a Sor
    Yorum Ekle
  16. GoPro Hero+ LCD Lens Replacement, Lens: adım 16, 3 resimden 1. GoPro Hero+ LCD Lens Replacement, Lens: adım 16, 3 resimden 2. GoPro Hero+ LCD Lens Replacement, Lens: adım 16, 3 resimden 3.
    • Remove the two 4 mm Phillips #000 screws securing the top button.
    FixBot'a Sor
    Yorum Ekle
  17. GoPro Hero+ LCD Lens Replacement: adım 17, 2 resimden 1. GoPro Hero+ LCD Lens Replacement: adım 17, 2 resimden 2.
    • Remove the four 4 mm Phillips #000 screws securing the lens to the case.
    FixBot'a Sor
    Yorum Ekle
  18. GoPro Hero+ LCD Lens Replacement: adım 18, 3 resimden 1. GoPro Hero+ LCD Lens Replacement: adım 18, 3 resimden 2. GoPro Hero+ LCD Lens Replacement: adım 18, 3 resimden 3.
    • Gently lift the lens up and out of the device.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Matthew Tinkey
922 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-4, Blackwell Fall 2015 USF Tampa, Team 2-4, Blackwell Fall 2015 üyesi
USFT-BLACKWELL-F15S2G4
4 Üyeler
20 adet Kılavuz yazıldı
2Kılavuz Yorumları
I'm curious if you have any suggestions for sourcing the replacement part.
Driftless Repair - Yanıt Paylaş
My hing clip is broken, Can I remove the actual camera & replace the full waterproof case then reinstall my camera into the new replacement case ?
jimmac044 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 47
Her zaman: 7,346
