Ana içeriğe geç
GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement
Neye ihtiyacın var
  1. GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement, Back Panel: adım 1, 2 resimden 1. GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement, Back Panel: adım 1, 2 resimden 2.
    • Be sure to power off the GoPro before you start disassembly.
    • Pop up and pull back on the clip to remove the screen cover and expose the back panel with the touchscreen.
    FixBot'a Sor
    Yorum Ekle
  2. GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement: adım 2, 2 resimden 1. GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement: adım 2, 2 resimden 2.
    • Use the metal spudger to pry around the perimeter of the panel.
    • Pry the panel upwards by inserting the metal spudger into the corner crease between the panel and camera shell.
    FixBot'a Sor
    Yorum Ekle
  3. GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement: adım 3, 2 resimden 1. GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement: adım 3, 2 resimden 2.
    • Pry around the panel to ensure it is not attached to the device.
    • Move the panel to the side so you can access the internal components.
    • The panel is still attached to the rest of the device with a ribbon cable, so be sure to not tear or damage the cable.
    FixBot'a Sor
    Yorum Ekle
  4. GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement, Battery: adım 4, 1 resimden 1.
    • Peel back the rear panel ribbon cable that is adhered to the battery until it is completely separated from the battery.
    • Be careful of metal contacts on strip; they can be sharp.
    FixBot'a Sor
    Yorum Ekle
  5. GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement: adım 5, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Using tweezers, peel off the copper tape on the right side of the battery.
    FixBot'a Sor
    Yorum Ekle
  6. GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement: adım 6, 2 resimden 1. GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement: adım 6, 2 resimden 2.
    • Place the plastic opening tool at one of the edges of the battery then pry until the battery is removed from the GoPro.
    FixBot'a Sor
    Yorum Ekle
  7. GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement: adım 7, 1 resimden 1.
    • Use a pair of tweezers to disconnect the battery connector from the motherboard.
    • Gently pull the battery off the motherboard. Pulling vertically off the motherboard will give a clean release.
    FixBot'a Sor
    Yorum Ekle
  8. GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement, MicroSD/Micro USB Port Assembly: adım 8, 3 resimden 1. GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement, MicroSD/Micro USB Port Assembly: adım 8, 3 resimden 2. GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement, MicroSD/Micro USB Port Assembly: adım 8, 3 resimden 3.
    • Remove the two 6 mm Phillips #00 screws.
    • Remove the single 4 mm Phillips #000 screws.
    FixBot'a Sor
    Yorum Ekle
  9. GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement: adım 9, 1 resimden 1.
    • Remove the image sensor from the camera.
    • You do not have to unplug the black box to remove the USB/SD chip.
    FixBot'a Sor
    Yorum Ekle
  10. GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement: adım 10, 1 resimden 1.
    • Grab the edge of the ribbon cable with the tweezers and gently pull until the cable is disconnected from the motherboard.
    • Be careful when removing the ribbon cable. You must pull gently or you can rip the ribbon off of its contacts.
    FixBot'a Sor
    Yorum Ekle
  11. GoPro Hero+ LCD MicroSD/Micro USB Port Assembly Replacement: adım 11, 1 resimden 1.
    • Gently lift the microSD/Micro USB assembly up and out of the device.
    FixBot'a Sor
    Yorum Ekle
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Shariyf Mitchell
207 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 2-4, Blackwell Fall 2015 USF Tampa, Team 2-4, Blackwell Fall 2015 üyesi
USFT-BLACKWELL-F15S2G4
4 Üyeler
20 adet Kılavuz yazıldı
2Kılavuz Yorumları
Hi were can i buy the microSD/Micro USB port assembly in your GoPro Hero+ LCD.
Hector - Yanıt Paylaş
Very helpful guide
Ninigo Marine Contractor - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 58
Her zaman: 4,226
