Ana içeriğe geç
GoPro Hero 3+ Silver Edition Motherboard Replacement
Neye ihtiyacın var
  1. GoPro Hero 3+ Silver Edition Motherboard Replacement, Battery: adım 1, 2 resimden 1. GoPro Hero 3+ Silver Edition Motherboard Replacement, Battery: adım 1, 2 resimden 2.
    • Push the tab on the back of the device left to remove the plate covering the battery.
  2. GoPro Hero 3+ Silver Edition Motherboard Replacement: adım 2, 1 resimden 1.
    • Use the strip of tape on the battery to remove the battery from the housing.
  3. GoPro Hero 3+ Silver Edition Motherboard Replacement, Front Panel: adım 3, 1 resimden 1.
    • Insert a plastic opening tool in between the front face plate and the black housing.
    • Make sure you insert the plastic opening tool next to the microSD card slot. There is a small gap that will help separate the face plate.
  4. GoPro Hero 3+ Silver Edition Motherboard Replacement: adım 4, 1 resimden 1.
    • Continue to use the plastic opening tool and separate the front face plate from the rest of the device.
    • There is adhesive that helps attach the front face plate. Some extra prying may be required to separate the face plate, but do not use excessive force.
  5. GoPro Hero 3+ Silver Edition Motherboard Replacement, Image Sensor: adım 5, 3 resimden 1. GoPro Hero 3+ Silver Edition Motherboard Replacement, Image Sensor: adım 5, 3 resimden 2. GoPro Hero 3+ Silver Edition Motherboard Replacement, Image Sensor: adım 5, 3 resimden 3.
    • Locate the four 8.1mm PH00 screws on the corners of the GoPro and unscrew them using the phillips screwdriver.
    • Gently remove the motherboard by using a plastic opening tool to pry it out of the housing.
    • Be careful not to damage the ribbon cable connected to the GoPro housing and motherboard.
  6. GoPro Hero 3+ Silver Edition Motherboard Replacement: adım 6, 2 resimden 1. GoPro Hero 3+ Silver Edition Motherboard Replacement: adım 6, 2 resimden 2.
    • Remove the ribbon cable by carefully flipping the black clip up with the plastic opening tool and pulling the cable out.
  7. GoPro Hero 3+ Silver Edition Motherboard Replacement: adım 7, 1 resimden 1.
    • Remove the four 4mm PH00 screws attaching the image sensor to the motherboard with your screwdriver.
  8. GoPro Hero 3+ Silver Edition Motherboard Replacement: adım 8, 2 resimden 1. GoPro Hero 3+ Silver Edition Motherboard Replacement: adım 8, 2 resimden 2.
    • Pry off the last ribbon cable with a plastic opening tool.
    • Remove the image sensor from the motherboard.
  9. GoPro Hero 3+ Silver Edition Motherboard Replacement, Motherboard: adım 9, 1 resimden 1.
    • Remove the single 3.2mm PH00 screw with your screwdriver to detach the motherboard from the mid frame.
  10. GoPro Hero 3+ Silver Edition Motherboard Replacement: adım 10, 3 resimden 1. GoPro Hero 3+ Silver Edition Motherboard Replacement: adım 10, 3 resimden 2. GoPro Hero 3+ Silver Edition Motherboard Replacement: adım 10, 3 resimden 3.
    • Use a plastic opening tool to gently separate the LCD ribbon cable from the motherboard.
    • Gently remove the motherboard from the midframe using tweezers.
    • Remove motherboard by lifting from the edges. This will reduce the chance of damaging components on the motherboard.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Blake Ehlers
668 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 5-8, Maness Fall 2015 Cal Poly, Team 5-8, Maness Fall 2015 üyesi
CPSU-MANESS-F15S5G8
4 Üyeler
12 adet Kılavuz yazıldı
2 Yorum
hi, where i can find the matherboard for de hero 3+ silver?
Mauricio - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 9
Her zaman: 3,444
