Ana içeriğe geç
GoPro Hero 3 Silver Expansion Port Replacement
Neye ihtiyacın var
  1. GoPro Hero 3 Silver Expansion Port Replacement, Battery: adım 1, 2 resimden 1. GoPro Hero 3 Silver Expansion Port Replacement, Battery: adım 1, 2 resimden 2.
    • Pull back on the tab on the back of GoPro to open the battery cover.
  2. GoPro Hero 3 Silver Expansion Port Replacement: adım 2, 1 resimden 1.
    • Pull the battery out using the tab.
  3. GoPro Hero 3 Silver Expansion Port Replacement, Expansion Port: adım 3, 2 resimden 1. GoPro Hero 3 Silver Expansion Port Replacement, Expansion Port: adım 3, 2 resimden 2.
    • Use the plastic opening tool to remove the faceplate.
    • There is some adhesive and clips so be careful and the faceplate should pop right off.
  4. GoPro Hero 3 Silver Expansion Port Replacement: adım 4, 2 resimden 1. GoPro Hero 3 Silver Expansion Port Replacement: adım 4, 2 resimden 2.
    • Now that the faceplate is off, it is time to remove the 4 screws on each corner.
    • Use the T4 tool bit from the iFixit toolkit in order to remove the 4 screws on each corner.
  5. GoPro Hero 3 Silver Expansion Port Replacement: adım 5, 2 resimden 1. GoPro Hero 3 Silver Expansion Port Replacement: adım 5, 2 resimden 2.
    • Note: Make sure you remove the door cover of the USB, mini HDMI, and SD port before. Separating the motherboard will be easier.
    • Using the plastic opening tool, slowly pry open the motherboard assembly.
  6. GoPro Hero 3 Silver Expansion Port Replacement: adım 6, 2 resimden 1. GoPro Hero 3 Silver Expansion Port Replacement: adım 6, 2 resimden 2.
    • Use the spudger to gently pry off the connector of the housing to the motherboard.
    • You should now have the motherboard assembly and the housing separated.
  7. GoPro Hero 3 Silver Expansion Port Replacement: adım 7, 3 resimden 1. GoPro Hero 3 Silver Expansion Port Replacement: adım 7, 3 resimden 2. GoPro Hero 3 Silver Expansion Port Replacement: adım 7, 3 resimden 3.
    • Use the spudger to remove the heat shield tape and detach the image sensor from the motherboard.
    • Using the T4 Torx toolbit, remove the 4 screws that connect the sensor to the lens.
    • Remove the silver connector of the image sensor from the motherboard using the spudger to pry it off.
  8. GoPro Hero 3 Silver Expansion Port Replacement: adım 8, 2 resimden 1. GoPro Hero 3 Silver Expansion Port Replacement: adım 8, 2 resimden 2.
    • The media adapter is attached to the motherboard via 3 screws:
    • x1 T4 Torx
    • x2 Phillips #00
    • There is a little silver bracket (in the yellow circle) that is held down by the Phillips #00 screw so be careful not to lose it.
  9. GoPro Hero 3 Silver Expansion Port Replacement: adım 9, 2 resimden 1. GoPro Hero 3 Silver Expansion Port Replacement: adım 9, 2 resimden 2.
    • With a little prying, use the spudger to detach the media adapter's connector from the motherboard.
    • Remove the media adapter from the motherboard.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Brian Alvarez
1.439 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 24-7, Lancaster Spring 2015 Cal Poly, Team 24-7, Lancaster Spring 2015 üyesi
CPSU-LANCASTER-S15S24G7
3 Üyeler
21 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 25
Her zaman: 1,978
