Ana içeriğe geç
GoPro Hero 3 Silver Rear Housing Replacement
Neye ihtiyacın var
  1. GoPro Hero 3 Silver Rear Housing Replacement, Battery: adım 1, 2 resimden 1. GoPro Hero 3 Silver Rear Housing Replacement, Battery: adım 1, 2 resimden 2.
    • Pull back on the tab on the back of GoPro to open the battery cover.
  2. GoPro Hero 3 Silver Rear Housing Replacement: adım 2, 1 resimden 1.
    • Pull the battery out using the tab.
  3. GoPro Hero 3 Silver Rear Housing Replacement, Rear Housing: adım 3, 2 resimden 1. GoPro Hero 3 Silver Rear Housing Replacement, Rear Housing: adım 3, 2 resimden 2.
    • Use the plastic opening tool to remove the faceplate.
    • There is some adhesive and clips so be careful and the faceplate should pop right off.
  4. GoPro Hero 3 Silver Rear Housing Replacement: adım 4, 2 resimden 1. GoPro Hero 3 Silver Rear Housing Replacement: adım 4, 2 resimden 2.
    • Now that the faceplate is off, it is time to remove the 4 screws on each corner.
    • Use the T4 tool bit from the iFixit toolkit in order to remove the 4 screws on each corner.
  5. GoPro Hero 3 Silver Rear Housing Replacement: adım 5, 2 resimden 1. GoPro Hero 3 Silver Rear Housing Replacement: adım 5, 2 resimden 2.
    • Note: Make sure you remove the door cover of the USB, mini HDMI, and SD port before. Separating the motherboard will be easier.
    • Using the plastic opening tool, slowly pry open the motherboard assembly.
  6. GoPro Hero 3 Silver Rear Housing Replacement: adım 6, 2 resimden 1. GoPro Hero 3 Silver Rear Housing Replacement: adım 6, 2 resimden 2.
    • Use the spudger to gently pry off the connector of the housing to the motherboard.
    • You should now have the motherboard assembly and the housing separated.
  7. GoPro Hero 3 Silver Rear Housing Replacement: adım 7, 1 resimden 1.
    • In order to replace the buttons. The entire housing has to be replaced.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Brian Alvarez
1.439 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 24-7, Lancaster Spring 2015 Cal Poly, Team 24-7, Lancaster Spring 2015 üyesi
CPSU-LANCASTER-S15S24G7
3 Üyeler
21 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 11
Her zaman: 2,571
