Ana içeriğe geç
GoPro Hero 4 Black Charging Port Replacement
Arşivlenmiş Kılavuz
Bu kılavuz sadece arşivsel amaçlarla muhafaza edilmiştir. Onarımınızı gerçekleştirmek için kılavuzun güncel halini kullanın.
Neye ihtiyacın var
  1. GoPro Hero 4 Black Charging Port  Replacement, Charging Port: adım 1, 1 resimden 1.
    • The first step to removing the faceplate is carefully moving the opening tool around the edge.
    • After loosening the clips on the edge, pull the faceplate off. Be aware that there is double-sided stick tape holding it on (indicated by the red arrow).
  2. GoPro Hero 4 Black Charging Port  Replacement: adım 2, 1 resimden 1.
    • Remove the four Phillips #000 screws.
    • The screws circled in red are longer than the screw circled in orange.
  3. GoPro Hero 4 Black Charging Port  Replacement: adım 3, 1 resimden 1.
    • Remove the camera and boards from the black plastic housing. You can use many tools to do this. We found that using the plastic opening tool may assist in the removal.
  4. GoPro Hero 4 Black Charging Port  Replacement: adım 4, 1 resimden 1.
    • Remove the ribbon cable by simply pulling on it. This will remove it from its connection.
    • Push down on the three wires and the clip will disconnect from the motherboard.
  5. GoPro Hero 4 Black Charging Port  Replacement: adım 5, 1 resimden 1.
    • Once the screws are removed and out of the way, gently remove the board. As you lift the board, the computer chip (outlined in orange) will separate from the motherboard.
  6. GoPro Hero 4 Black Charging Port  Replacement: adım 6, 1 resimden 1.
    • Take your screwdriver with the PH000 Philips head attachment on it and remove the four screws outlined in red.
    • Just like before, just pull up on the ribbon strip and remove the connector from the motherboard.
  7. GoPro Hero 4 Black Charging Port  Replacement: adım 7, 1 resimden 1.
    • Remove these two screws and remove the riser that is being held in by the screws.
  8. GoPro Hero 4 Black Charging Port  Replacement: adım 8, 1 resimden 1.
    • Remove the screw holding the motherboard in place.
    • Do not attempt to remove the motherboard at this stage, as it is still attached by a ribbon cable.
  9. GoPro Hero 4 Black Charging Port  Replacement: adım 9, 1 resimden 1.
    Bu adımda kullanılan alet:
    • At the top of the ribbon cable, there is a black clip that needs to be popped up.
    • You can use your finger to pop this up. But, a pair of needle nose tweezers might help.
  10. GoPro Hero 4 Black Charging Port  Replacement: adım 10, 1 resimden 1.
    • Gently grab the ribbon with the needle nose tweezers and pull down. This will disconnect the ribbon from the connector.
    • Now, the motherboard can be removed. Due to the USB connector being on the motherboard, the entire board needs to be replaced.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Jonathan Campbell
830 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team 1-2, Hagerty Fall 2015 IUPUI, Team 1-2, Hagerty Fall 2015 üyesi
IUPUI-HAGERTY-F15S1G2
3 Üyeler
1Rehber Yorum
got a part number for the USB? digikey?
hazakins - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 50
Her zaman: 4,439
