Ana içeriğe geç
GoPro Hero LCD Screen Replacement
Neye ihtiyacın var
  1. GoPro Hero LCD Screen Replacement, Casing: adım 1, 1 resimden 1.
    • Power off your GoPro before beginning disassembly.
    • Unclip the black latch to the camera case and open the case.
    FixBot'a Sor
    Yorum Ekle
  2. GoPro Hero LCD Screen Replacement: adım 2, 1 resimden 1.
    • Gently pry the back open by inserting a metal spudger between the case and back panel.
    FixBot'a Sor
    Yorum Ekle
  3. GoPro Hero LCD Screen Replacement: adım 3, 1 resimden 1.
    • Disconnect the battery from the motherboard by unplugging the red, white, and black wires from the white adapter.
    FixBot'a Sor
    Yorum Ekle
  4. GoPro Hero LCD Screen Replacement: adım 4, 1 resimden 1.
    • Disconnect the ribbon cable from the lens by lifting the black latch and gently pulling the ribbon cable from the socket.
    FixBot'a Sor
    Yorum Ekle
  5. GoPro Hero LCD Screen Replacement: adım 5, 1 resimden 1.
    • Use a Phillips screwdriver (PH000) to remove the four screws around the white plastic piece.
    • Make sure to keep track of these screws as they are very small.
    FixBot'a Sor
    Yorum Ekle
  6. GoPro Hero LCD Screen Replacement: adım 6, 1 resimden 1.
    • Carefully remove the motherboard and white plastic piece from the case.
    FixBot'a Sor
    Yorum Ekle
  7. GoPro Hero LCD Screen Replacement, LCD Screen: adım 7, 2 resimden 1. GoPro Hero LCD Screen Replacement, LCD Screen: adım 7, 2 resimden 2.
    • Remove the larger ribbon cable from the daughter board by lifting the black latch and pulling the ribbon cable gently from the socket.
    • Disconnect the smaller ribbon cable leading from the white plastic piece by simply pulling it from the socket.
    FixBot'a Sor
    Yorum Ekle
  8. GoPro Hero LCD Screen Replacement: adım 8, 1 resimden 1.
    • Separate the motherboard from the white piece of plastic.
    FixBot'a Sor
    Yorum Ekle
  9. GoPro Hero LCD Screen Replacement: adım 9, 1 resimden 1.
    • Remove the ribbon cable from the motherboard by simply pulling the cable from the socket.
    FixBot'a Sor
    Yorum Ekle
  10. GoPro Hero LCD Screen Replacement: adım 10, 2 resimden 1. GoPro Hero LCD Screen Replacement: adım 10, 2 resimden 2.
    • Separate the LCD screen from the motherboard.
    FixBot'a Sor
    Yorum Ekle
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
River Drake
1.065 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 12-2, Lancaster Spring 2015 Cal Poly, Team 12-2, Lancaster Spring 2015 üyesi
CPSU-LANCASTER-S15S12G2
4 Üyeler
18 adet Kılavuz yazıldı
3Kılavuz Yorumları
Where do you buy the replacement lcd
Anthony Volatile - Yanıt Paylaş
Gopro hero 7 white repair cost:
Screen: $45 - https://www.ebay.com.au/itm/183828969944
Side panel: $35 - https://www.herogear.com.au/genuine-repl...
Addisen KING - Yanıt Paylaş
I can find the screen but is it compatible with the Hero+
Brian Casado - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 26
Son 30 gün: 131
Her zaman: 27,287
