Ana içeriğe geç
GoPro Hero Lens Replacement
Neye ihtiyacın var
    1. GoPro Hero Lens Replacement, Casing: adım 1, 1 resimden 1.
      • Power off your GoPro before beginning disassembly.
      • Unclip the black latch to the camera case and open the case.
      FixBot'a Sor
      Yorum Ekle
    2. GoPro Hero Lens Replacement: adım 2, 1 resimden 1.
      • Gently pry the back open by inserting a metal spudger between the case and back panel.
      FixBot'a Sor
      Yorum Ekle
    3. GoPro Hero Lens Replacement: adım 3, 1 resimden 1.
      • Disconnect the battery from the motherboard by unplugging the red, white, and black wires from the white adapter.
      FixBot'a Sor
      Yorum Ekle
    4. GoPro Hero Lens Replacement: adım 4, 1 resimden 1.
      • Disconnect the ribbon cable from the lens by lifting the black latch and gently pulling the ribbon cable from the socket.
      FixBot'a Sor
      Yorum Ekle
    5. GoPro Hero Lens Replacement: adım 5, 1 resimden 1.
      • Use a Phillips screwdriver (PH000) to remove the four screws around the white plastic piece.
      • Make sure to keep track of these screws as they are very small.
      FixBot'a Sor
      Yorum Ekle
    6. GoPro Hero Lens Replacement: adım 6, 1 resimden 1.
      • Carefully remove the motherboard and white plastic piece from the case.
      FixBot'a Sor
      Yorum Ekle
    1. GoPro Hero Lens Replacement, Lens: adım 7, 1 resimden 1.
      • Remove the four screws from the lens.
      • These screws are smaller than the ones removed from the white plastic piece.
      FixBot'a Sor
      Yorum Ekle
    2. GoPro Hero Lens Replacement: adım 8, 1 resimden 1.
      • Remove the lens from the case.
      FixBot'a Sor
      Yorum Ekle
Sonuç
To reassemble your device, follow the instructions in reverse order.
3 farklı kişi bu kılavuzu tamamladı.
River Drake
1.065 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 12-2, Lancaster Spring 2015 Cal Poly, Team 12-2, Lancaster Spring 2015 üyesi
CPSU-LANCASTER-S15S12G2
4 Üyeler
24 adet Kılavuz yazıldı
1Rehber Yorum
I followed this list, but I think I knocked a component off of the motherboard while I was unscrewing it. I wasn’t planning on ever putting it back together, since I have a newer GoPro camera. Luckily, the lens and the cable connecting it didn’t get damaged. Is there maybe a way to connect the lens to the Raspberry Pi Zero?
Doggo Boi - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 12
Son 30 gün: 76
Her zaman: 14,234
