Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Unclip the black latch to the camera case and open the case.
Gently pry the back open by inserting a metal spudger between the case and back panel.
Disconnect the battery from the motherboard by unplugging the red, white, and black wires from the white adapter.
Disconnect the ribbon cable from the lens by lifting the black latch and gently pulling the ribbon cable from the socket.
Use a Phillips screwdriver (PH000) to remove the four screws around the white plastic piece.
Carefully remove the motherboard and white plastic piece from the case.
3 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
I followed this list, but I think I knocked a component off of the motherboard while I was unscrewing it. I wasn’t planning on ever putting it back together, since I have a newer GoPro camera. Luckily, the lens and the cable connecting it didn’t get damaged. Is there maybe a way to connect the lens to the Raspberry Pi Zero?
