Ana içeriğe geç
GoPro Hero Motherboard Replacement
Neye ihtiyacın var
  1. GoPro Hero Motherboard Replacement, Casing: adım 1, 1 resimden 1.
    • Power off your GoPro before beginning disassembly.
    • Unclip the black latch to the camera case and open the case.
  2. GoPro Hero Motherboard Replacement: adım 2, 1 resimden 1.
    • Gently pry the back open by inserting a metal spudger between the case and back panel.
  3. GoPro Hero Motherboard Replacement: adım 3, 1 resimden 1.
    • Disconnect the battery from the motherboard by unplugging the red, white, and black wires from the white adapter.
  4. GoPro Hero Motherboard Replacement: adım 4, 1 resimden 1.
    • Disconnect the ribbon cable from the lens by lifting the black latch and gently pulling the ribbon cable from the socket.
  5. GoPro Hero Motherboard Replacement: adım 5, 1 resimden 1.
    • Use a Phillips screwdriver (PH000) to remove the four screws around the white plastic piece.
    • Make sure to keep track of these screws as they are very small.
  6. GoPro Hero Motherboard Replacement: adım 6, 1 resimden 1.
    • Carefully remove the motherboard and white plastic piece from the case.
  7. GoPro Hero Motherboard Replacement, Motherboard: adım 7, 2 resimden 1. GoPro Hero Motherboard Replacement, Motherboard: adım 7, 2 resimden 2.
    • Remove the larger ribbon cable from the daughter board by lifting the black latch and pulling the ribbon cable gently from the socket.
    • Disconnect the smaller ribbon cable leading from the white plastic piece by simply pulling it from the socket.
  8. GoPro Hero Motherboard Replacement: adım 8, 2 resimden 1. GoPro Hero Motherboard Replacement: adım 8, 2 resimden 2.
    • Separate the white plastic piece from the motherboard.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Zoe Tuggle
179 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 12-2, Lancaster Spring 2015 Cal Poly, Team 12-2, Lancaster Spring 2015 üyesi
CPSU-LANCASTER-S15S12G2
4 Üyeler
18 adet Kılavuz yazıldı
2Kılavuz Yorumları
So after doing all theses steps did it resolve the problem
Anita - Yanıt
Thanks so much I really needed this guide.
Thanks, Sam
Sam Liam Matthews - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 76
Her zaman: 10,763
