Ana içeriğe geç
GoPro Hero3+ Black Edition Camera Lens Replacement
Neye ihtiyacın var
  1. GoPro Hero3+ Black Edition Camera Lens Replacement, Battery: adım 1, 1 resimden 1.
    • Pull the tab on the back of the device to release the back cover. It should come right off.
    • The device pictured does not include the back cover.
    FixBot'a Sor
    Yorum Ekle
  2. GoPro Hero3+ Black Edition Camera Lens Replacement: adım 2, 1 resimden 1.
    • Use the battery tab to pull the battery out of the device.
    FixBot'a Sor
    Yorum Ekle
    • Remove the battery from the slot.
    FixBot'a Sor
    Yorum Ekle
  3. GoPro Hero3+ Black Edition Camera Lens Replacement, Front Face Plate: adım 4, 2 resimden 1. GoPro Hero3+ Black Edition Camera Lens Replacement, Front Face Plate: adım 4, 2 resimden 2.
    • Using a plastic opening tool, pry the gray, front face plate until it can be removed from the housing.
    • To avoid breaking or weakening the tabs on the face plate which hold it in place, alternate the sides from which you pry and check each tab before separating the plate from the body.
    FixBot'a Sor
    Yorum Ekle
  4. GoPro Hero3+ Black Edition Camera Lens Replacement, Image Sensor: adım 5, 3 resimden 1. GoPro Hero3+ Black Edition Camera Lens Replacement, Image Sensor: adım 5, 3 resimden 2. GoPro Hero3+ Black Edition Camera Lens Replacement, Image Sensor: adım 5, 3 resimden 3.
    • Using your screwdriver, remove the four 8.1mm PH00 screws securing the motherboard to the black housing unit and set them aside.
    • Use the plastic opening tool to help pry the motherboard/midframe up from the main housing. Once you can get a hold of the edge, simply pull the internal components up and out!
    • Watch out for the ribbon cable connecting the midframe and the motherboard to the GoPro housing. See the next step.
    FixBot'a Sor
    Yorum Ekle
  5. GoPro Hero3+ Black Edition Camera Lens Replacement: adım 6, 2 resimden 1. GoPro Hero3+ Black Edition Camera Lens Replacement: adım 6, 2 resimden 2.
    • Remove the ribbon cable connecting the housing to the motherboard by flicking up the black clip with the spudger tool and gently pulling the cable out.
    FixBot'a Sor
    Yorum Ekle
  6. GoPro Hero3+ Black Edition Camera Lens Replacement: adım 7, 1 resimden 1.
    • Once the internal components are removed, take out your handy dandy spudger tool and pry off the piece of tape that holds down the image sensor.
    • Disclaimer: Our device is just a teardown unit and no longer has the tape. The markup depicts the location where the tape would be located.
    FixBot'a Sor
    Yorum Ekle
  7. GoPro Hero3+ Black Edition Camera Lens Replacement: adım 8, 1 resimden 1.
    • Using your screwdriver, remove the four PH00 screws securing the image sensor to the motherboard.
    • Disclaimer: The unit used for this guide did not include these screws. Set them aside so you do not mix them up with the previously removed screws.
    FixBot'a Sor
    Yorum Ekle
  8. GoPro Hero3+ Black Edition Camera Lens Replacement: adım 9, 2 resimden 1. GoPro Hero3+ Black Edition Camera Lens Replacement: adım 9, 2 resimden 2.
    • Using the spudger tool, pry off the connector ribbon from the motherboard (don't worry it comes off pretty easily).
    • Remove the image sensor from the motherboard assembly.
    FixBot'a Sor
    Yorum Ekle
  9. GoPro Hero3+ Black Edition Camera Lens Replacement, microSD and Accessory Board: adım 10, 1 resimden 1.
    • Using your screwdriver, remove the three 4mm PH00 screws that hold down the metal plate.
    FixBot'a Sor
    Yorum Ekle
  10. GoPro Hero3+ Black Edition Camera Lens Replacement: adım 11, 2 resimden 1. GoPro Hero3+ Black Edition Camera Lens Replacement: adım 11, 2 resimden 2.
    • Using the spudger tool, pry off the corresponding ribbon cable from the motherboard.
    • The microSD/accessory board is ready to come off.
    FixBot'a Sor
    Yorum Ekle
  11. GoPro Hero3+ Black Edition Camera Lens Replacement, Motherboard: adım 12, 1 resimden 1.
    • Using your trusty screwdriver, remove the single 3.2mm PH00 screw connecting the motherboard to the midframe.
    FixBot'a Sor
    Yorum Ekle
  12. GoPro Hero3+ Black Edition Camera Lens Replacement: adım 13, 3 resimden 1. GoPro Hero3+ Black Edition Camera Lens Replacement: adım 13, 3 resimden 2. GoPro Hero3+ Black Edition Camera Lens Replacement: adım 13, 3 resimden 3.
    • Use the spudger tool to disconnect the front LCD from the motherboard. Gently pull the ribbon cable out.
    • Gently pull the motherboard away from the midframe.
    FixBot'a Sor
    Yorum Ekle
  13. GoPro Hero3+ Black Edition Camera Lens Replacement, Camera Lens: adım 14, 2 resimden 1. GoPro Hero3+ Black Edition Camera Lens Replacement, Camera Lens: adım 14, 2 resimden 2.
    • Simply use your PH00 screwdriver to remove the last three screws, and the lens housing is ready to come off.
    FixBot'a Sor
    Yorum Ekle
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Tyler Fox
272 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 6-15, Maness Spring 2015 Cal Poly, Team 6-15, Maness Spring 2015 üyesi
CPSU-MANESS-S15S6G15
4 Üyeler
13 adet Kılavuz yazıldı
1Rehber Yorum
Hey, is there any lens to replace the original one you can recommend? I've seen prices from 15 to 80 Euro, basically everyone claiming the same features (170°).
Rick - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 37
Her zaman: 4,537
