Giriş
Are you having trouble saving all of the cool videos and photos you record? You've tried everything and nothing will work? It may be time to get a new microSD and accessory board so you can enjoy the adventures for years to come!
Neye ihtiyacın var
Pull the tab on the back of the device to release the back cover. It should come right off.
Using a plastic opening tool, pry the gray, front face plate until it can be removed from the housing.
Using your screwdriver, remove the four 8.1mm PH00 screws securing the motherboard to the black housing unit and set them aside.
Use the plastic opening tool to help pry the motherboard/midframe up from the main housing. Once you can get a hold of the edge, simply pull the internal components up and out!
Using your screwdriver, remove the three 4mm PH00 screws that hold down the metal plate.
6 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
I bought a replacement from iFixit. I follow the guide, but it still shows same error “No SD”. Any advice?
