Giriş
You've had a terrible accident and realized that your GoPro has a crack right through the center of the lens! Use our guide to resurrect you GoPro back to life!
Neye ihtiyacın var
Push the tab on the back of the device left to remove the plate covering the battery.
Insert a plastic opening tool in between the front face plate and the black housing.
Locate the four 8.1mm PH00 screws on the corners of the GoPro and unscrew them using the phillips screwdriver.
Gently remove the motherboard by using a plastic opening tool to pry it out of the housing.
Using your screwdriver, unscrew three 4mm PH00 screws that will free the metal plate.
Remove the single 3.2mm PH00 screw with your screwdriver to detach the motherboard from the mid frame.
Use your PH00 screwdriver to remove the last three screws from the mid frame. This will release the lens housing from the mid frame.
9 farklı kişi bu kılavuzu tamamladı.
