Ana içeriğe geç
GoPro Hero3+ Silver Edition Front Panel Replacement
Neye ihtiyacın var
  1. GoPro Hero3+ Silver Edition Front Panel Replacement, Front Panel: adım 1, 1 resimden 1.
    • Insert a plastic opening tool in between the front face plate and the black housing.
    • Make sure you insert the plastic opening tool next to the microSD card slot. There is a small gap that will help separate the face plate.
  2. GoPro Hero3+ Silver Edition Front Panel Replacement: adım 2, 1 resimden 1.
    • Continue to use the plastic opening tool and separate the front face plate from the rest of the device.
    • There is adhesive that helps attach the front face plate. Some extra prying may be required to separate the face plate, but do not use excessive force.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Patrick Cook
687 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 5-8, Maness Fall 2015 Cal Poly, Team 5-8, Maness Fall 2015 üyesi
CPSU-MANESS-F15S5G8
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 11
Her zaman: 575
