Ana içeriğe geç
GoPro Hero3+ Silver Edition Front Panel Replacement
Neye ihtiyacın var
  1. GoPro Hero3+ Silver Edition Front Panel Replacement, Front Panel: adım 1, 1 resimden 1.
    • Insert a plastic opening tool in between the front face plate and the black housing.
    • Make sure you insert the plastic opening tool next to the microSD card slot. There is a small gap that will help separate the face plate.
    FixBot'a Sor
    Yorum Ekle
  2. GoPro Hero3+ Silver Edition Front Panel Replacement: adım 2, 1 resimden 1.
    • Continue to use the plastic opening tool and separate the front face plate from the rest of the device.
    • There is adhesive that helps attach the front face plate. Some extra prying may be required to separate the face plate, but do not use excessive force.
    FixBot'a Sor
    Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Patrick Cook
699 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 5-8, Maness Fall 2015 Cal Poly, Team 5-8, Maness Fall 2015 üyesi
CPSU-MANESS-F15S5G8
4 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 21
Her zaman: 973
