Ana içeriğe geç
GoPro Hero3+ Silver Edition Image Sensor Replacement
Neye ihtiyacın var
  1. GoPro Hero3+ Silver Edition Image Sensor Replacement, Battery: adım 1, 2 resimden 1. GoPro Hero3+ Silver Edition Image Sensor Replacement, Battery: adım 1, 2 resimden 2.
    • Push the tab on the back of the device left to remove the plate covering the battery.
    FixBot'a Sor
    Yorum Ekle
  2. GoPro Hero3+ Silver Edition Image Sensor Replacement: adım 2, 1 resimden 1.
    • Use the strip of tape on the battery to remove the battery from the housing.
    FixBot'a Sor
    Yorum Ekle
  3. GoPro Hero3+ Silver Edition Image Sensor Replacement, Front Panel: adım 3, 1 resimden 1.
    • Insert a plastic opening tool in between the front face plate and the black housing.
    • Make sure you insert the plastic opening tool next to the microSD card slot. There is a small gap that will help separate the face plate.
    FixBot'a Sor
    Yorum Ekle
  4. GoPro Hero3+ Silver Edition Image Sensor Replacement: adım 4, 1 resimden 1.
    • Continue to use the plastic opening tool and separate the front face plate from the rest of the device.
    • There is adhesive that helps attach the front face plate. Some extra prying may be required to separate the face plate, but do not use excessive force.
    FixBot'a Sor
    Yorum Ekle
  5. GoPro Hero3+ Silver Edition Image Sensor Replacement, Image Sensor: adım 5, 3 resimden 1. GoPro Hero3+ Silver Edition Image Sensor Replacement, Image Sensor: adım 5, 3 resimden 2. GoPro Hero3+ Silver Edition Image Sensor Replacement, Image Sensor: adım 5, 3 resimden 3.
    • Locate the four 8.1mm PH00 screws on the corners of the GoPro and unscrew them using the phillips screwdriver.
    • Gently remove the motherboard by using a plastic opening tool to pry it out of the housing.
    • Be careful not to damage the ribbon cable connected to the GoPro housing and motherboard.
    FixBot'a Sor
    Yorum Ekle
  6. GoPro Hero3+ Silver Edition Image Sensor Replacement: adım 6, 2 resimden 1. GoPro Hero3+ Silver Edition Image Sensor Replacement: adım 6, 2 resimden 2.
    • Remove the ribbon cable by carefully flipping the black clip up with the plastic opening tool and pulling the cable out.
    FixBot'a Sor
    Yorum Ekle
  7. GoPro Hero3+ Silver Edition Image Sensor Replacement: adım 7, 1 resimden 1.
    • Remove the four 4mm PH00 screws attaching the image sensor to the motherboard with your screwdriver.
    FixBot'a Sor
    Yorum Ekle
  8. GoPro Hero3+ Silver Edition Image Sensor Replacement: adım 8, 2 resimden 1. GoPro Hero3+ Silver Edition Image Sensor Replacement: adım 8, 2 resimden 2.
    • Pry off the last ribbon cable with a plastic opening tool.
    • Remove the image sensor from the motherboard.
    FixBot'a Sor
    Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Patrick Cook
699 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 5-8, Maness Fall 2015 Cal Poly, Team 5-8, Maness Fall 2015 üyesi
CPSU-MANESS-F15S5G8
4 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 33
Her zaman: 1,176
