Ana içeriğe geç
GoPro Hero4 Black Camera Sensor Replacement
Neye ihtiyacın var
    1. GoPro Hero4 Black Camera Sensor Replacement, Midframe Housing: adım 1, 3 resimden 1. GoPro Hero4 Black Camera Sensor Replacement, Midframe Housing: adım 1, 3 resimden 2. GoPro Hero4 Black Camera Sensor Replacement, Midframe Housing: adım 1, 3 resimden 3.
      Bu adımda kullanılan alet:
      • Remove the faceplate by carefully prying around the edge using a plastic opening tool. Loosen the clips on the edge, then pull the faceplate off.
      • Use the tweezers to lift the faceplate from the rest of the device.
      • The power button on the front of the GoPro may pop off. Ensure to align it properly during reassembly.
      FixBot'a Sor
      Yorum Ekle
    2. GoPro Hero4 Black Camera Sensor Replacement: adım 2, 2 resimden 1. GoPro Hero4 Black Camera Sensor Replacement: adım 2, 2 resimden 2.
      • Using a #00 Phillips head screwdriver, remove the following screws:
      • One 4.6 mm screw
      • Three 8.2 mm screws
      • Two 6.1 mm screws
      FixBot'a Sor
      Yorum Ekle
    3. GoPro Hero4 Black Camera Sensor Replacement: adım 3, 2 resimden 1. GoPro Hero4 Black Camera Sensor Replacement: adım 3, 2 resimden 2.
      • Insert a metal spudger between the back plastic housing and the camera board assembly. Working around the edge to be careful of the inner components, carefully remove the camera.
      FixBot'a Sor
      Yorum Ekle
    4. GoPro Hero4 Black Camera Sensor Replacement: adım 4, 3 resimden 1. GoPro Hero4 Black Camera Sensor Replacement: adım 4, 3 resimden 2. GoPro Hero4 Black Camera Sensor Replacement: adım 4, 3 resimden 3.
      • Using tweezers, remove the ribbon strip by pulling on it. This will remove the connection.
      • Push down on the three wires with the metal spudger and the clip will disconnect from the motherboard.
      • The clip must be pulled up and away from the motherboard. Attempting to slide it out will damage the clip.
      • During reassembly, remove the black tape on the ribbon cable, turn the camera upside down so you can see the port, and reinsert the cable with tweezers. It's a lot easier!
      FixBot'a Sor
      Yorum Ekle
    1. GoPro Hero4 Black Camera Sensor Replacement, Camera Sensor: adım 5, 3 resimden 1. GoPro Hero4 Black Camera Sensor Replacement, Camera Sensor: adım 5, 3 resimden 2. GoPro Hero4 Black Camera Sensor Replacement, Camera Sensor: adım 5, 3 resimden 3.
      • Using a plastic opening tool, separate the camera sensor's connector from the motherboard.
      FixBot'a Sor
      Yorum Ekle
    2. GoPro Hero4 Black Camera Sensor Replacement: adım 6, 3 resimden 1. GoPro Hero4 Black Camera Sensor Replacement: adım 6, 3 resimden 2. GoPro Hero4 Black Camera Sensor Replacement: adım 6, 3 resimden 3.
      • Using a #00 Phillips head screwdriver, remove the four 3.0mm screws holding the camera sensor.
      FixBot'a Sor
      Yorum Ekle
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Jeffrey Goethe
674 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S2-G1, Sullivan Spring 2017 USF Tampa, Team S2-G1, Sullivan Spring 2017 üyesi
USFT-SULLIVAN-S17S2G1
4 Üyeler
12 adet Kılavuz yazıldı
2Kılavuz Yorumları
not easy to return the ribbon back to its place! it’s easier to throw your gopro after doing this.
popoypoi22 - Yanıt Paylaş
Hi, is the sensor for black and silver same? Thank you
Jakub Kunický - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 12
Son 30 gün: 42
Her zaman: 4,689
