Ana içeriğe geç
GoPro Hero4 Black Lens Replacement
Neye ihtiyacın var
  1. GoPro Hero4 Black Lens Replacement, Midframe Housing: adım 1, 3 resimden 1. GoPro Hero4 Black Lens Replacement, Midframe Housing: adım 1, 3 resimden 2. GoPro Hero4 Black Lens Replacement, Midframe Housing: adım 1, 3 resimden 3.
    • Remove the faceplate by carefully prying around the edge using a plastic opening tool. Loosen the clips on the edge, then pull the faceplate off.
    • Use the tweezers to lift the faceplate from the rest of the device.
    • The power button on the front of the GoPro may pop off. Ensure to align it properly during reassembly.
  2. GoPro Hero4 Black Lens Replacement: adım 2, 2 resimden 1. GoPro Hero4 Black Lens Replacement: adım 2, 2 resimden 2.
    • Using a #00 Phillips head screwdriver, remove the following screws:
    • One 4.6 mm screw
    • Three 8.2 mm screws
    • Two 6.1 mm screws
  3. GoPro Hero4 Black Lens Replacement: adım 3, 2 resimden 1. GoPro Hero4 Black Lens Replacement: adım 3, 2 resimden 2.
    • Insert a metal spudger between the back plastic housing and the camera board assembly. Working around the edge to be careful of the inner components, carefully remove the camera.
  4. GoPro Hero4 Black Lens Replacement: adım 4, 3 resimden 1. GoPro Hero4 Black Lens Replacement: adım 4, 3 resimden 2. GoPro Hero4 Black Lens Replacement: adım 4, 3 resimden 3.
    • Using tweezers, remove the ribbon strip by pulling on it. This will remove the connection.
    • Push down on the three wires with the metal spudger and the clip will disconnect from the motherboard.
    • The clip must be pulled up and away from the motherboard. Attempting to slide it out will damage the clip.
    • During reassembly, remove the black tape on the ribbon cable, turn the camera upside down so you can see the port, and reinsert the cable with tweezers. It's a lot easier!
  5. GoPro Hero4 Black Lens Replacement, Camera Sensor: adım 5, 3 resimden 1. GoPro Hero4 Black Lens Replacement, Camera Sensor: adım 5, 3 resimden 2. GoPro Hero4 Black Lens Replacement, Camera Sensor: adım 5, 3 resimden 3.
    • Using a plastic opening tool, separate the camera sensor's connector from the motherboard.
  6. GoPro Hero4 Black Lens Replacement: adım 6, 3 resimden 1. GoPro Hero4 Black Lens Replacement: adım 6, 3 resimden 2. GoPro Hero4 Black Lens Replacement: adım 6, 3 resimden 3.
    • Using a #00 Phillips head screwdriver, remove the four 3.0mm screws holding the camera sensor.
  7. GoPro Hero4 Black Lens Replacement, Lens: adım 7, 2 resimden 1. GoPro Hero4 Black Lens Replacement, Lens: adım 7, 2 resimden 2.
    • Three 2 mm screw
  8. GoPro Hero4 Black Lens Replacement: adım 8, 1 resimden 1.
    • Lift the lens from the front housing.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Thomas Sullivan
589 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S2-G1, Sullivan Spring 2017 USF Tampa, Team S2-G1, Sullivan Spring 2017 üyesi
USFT-SULLIVAN-S17S2G1
4 Üyeler
12 adet Kılavuz yazıldı
Bir Yorum
Between step 6 and step 7, you skipped a really important step…
Matthew Mulholland - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 6
Son 30 gün: 19
Her zaman: 4,244
