Ana içeriğe geç
GoPro Hero4 Silver Image Sensor Replacement
Neye ihtiyacın var
    1. GoPro Hero4 Silver Image Sensor Replacement, Front Panel: adım 1, 3 resimden 1. GoPro Hero4 Silver Image Sensor Replacement, Front Panel: adım 1, 3 resimden 2. GoPro Hero4 Silver Image Sensor Replacement, Front Panel: adım 1, 3 resimden 3.
      • Start by removing the silver plastic face from the camera using a plastic opening tool. Insert the plastic opening tool into the middle of each edge and lift up the tabs that keep the camera face on.
      • The seven plastic tab locations are marked in red.
      • Try using the plastic opening tool before switching to the metal spudger. We tried using the plastic opening tool to pry the camera face off, but found that it did not give us enough leverage.
      • There may be glue holding the camera face on to the housing. Be careful not to flex the camera face too much, or it will crack.
      FixBot'a Sor
      Yorum Ekle
    1. GoPro Hero4 Silver Image Sensor Replacement, Image Sensor: adım 2, 1 resimden 1.
      • Remove the three 8 mm Phillips #000 screws on each corner of the camera.
      • Remove the single 4 mm Phillips #000 screw on the bottom left corner of the camera.
      FixBot'a Sor
      Yorum Ekle
    2. GoPro Hero4 Silver Image Sensor Replacement: adım 3, 2 resimden 1. GoPro Hero4 Silver Image Sensor Replacement: adım 3, 2 resimden 2.
      • To remove the motherboard assembly from the camera casing, use the plastic opening tool on the lens side of the camera to pry the motherboard assembly out of the camera housing.
      • To avoid breaking the plastic on the lens side of the camera (see photo), pry along the edges near the corners.
      • Try using the plastic opening tool before switching to the metal spudger. We tried using the plastic opening tool to pry the motherboard assembly open, but found that it did not give us enough leverage.
      • Do not try to pry near the power button side of the camera. This will break important cables inside.
      FixBot'a Sor
      Yorum Ekle
    3. GoPro Hero4 Silver Image Sensor Replacement: adım 4, 2 resimden 1. GoPro Hero4 Silver Image Sensor Replacement: adım 4, 2 resimden 2.
      • Remove the four 8 mm Phillips #000 screws securing the camera sensor assembly.
      FixBot'a Sor
      Yorum Ekle
    4. GoPro Hero4 Silver Image Sensor Replacement: adım 5, 3 resimden 1. GoPro Hero4 Silver Image Sensor Replacement: adım 5, 3 resimden 2. GoPro Hero4 Silver Image Sensor Replacement: adım 5, 3 resimden 3.
      • To remove the sensor assembly, simply peel off the lens towards the attached ribbon cable.
      • The sensor has ribbon cables running to the motherboard via a black rectangular connector.
      • To remove the sensor, use the spudger to pry up each side, Then, lift the connector straight up from its socket.
      • With the old camera sensor assembly removed, you can now replace it with a new sensor.
      FixBot'a Sor
      Yorum Ekle
Sonuç
11 farklı kişi bu kılavuzu tamamladı.
Bradley Welsh
764 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-1, Blackwell Fall 2015 USF Tampa, Team 2-1, Blackwell Fall 2015 üyesi
USFT-BLACKWELL-F15S2G1
4 Üyeler
26 adet Kılavuz yazıldı
3Kılavuz Yorumları
Did GoPro make an updated version of the sensor, or are all the ones sold on the web just the same as the one that keeps failing in the cameras? Do you have a part number for the sensor that is supposed to work better? No point replacing the sensor with the same one the camera came with as it will likely fail withing a year just like the original one. Please advice.
David Kvick - Yanıt Paylaş
thanks for the instructions - easy to understand and carry out. my GoPro 4 is now up and running again
Nigel Jones - Yanıt Paylaş
Pregunta el sensor de la go pro hero 4 black es el mismo de la gopro hero 4 silver???
Jacinto - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 18
Son 30 gün: 59
Her zaman: 15,058
