Ana içeriğe geç
GoPro Hero5 Black Back Housing Replacement
Neye ihtiyacın var
    1. GoPro Hero5 Black Back Housing Replacement, Battery: adım 1, 3 resimden 1. GoPro Hero5 Black Back Housing Replacement, Battery: adım 1, 3 resimden 2. GoPro Hero5 Black Back Housing Replacement, Battery: adım 1, 3 resimden 3.
      • While pressing the button on the bottom of the GoPro, slide the battery door to the side to pop it open.
      FixBot'a Sor
      Yorum Ekle
    2. GoPro Hero5 Black Back Housing Replacement: adım 2, 3 resimden 1. GoPro Hero5 Black Back Housing Replacement: adım 2, 3 resimden 2. GoPro Hero5 Black Back Housing Replacement: adım 2, 3 resimden 3.
      • Grab the plastic flap on the battery and pull the battery out.
      FixBot'a Sor
      Yorum Ekle
    1. GoPro Hero5 Black Back Housing Replacement, Back Housing: adım 3, 2 resimden 1. GoPro Hero5 Black Back Housing Replacement, Back Housing: adım 3, 2 resimden 2.
      • Pull and twist the lens cover right or left until it pops off.
      • The lens cover is secured tightly and might be difficult to twist off.
      FixBot'a Sor
      Yorum Ekle
    2. GoPro Hero5 Black Back Housing Replacement: adım 4, 1 resimden 1.
      • This step is not necessary but will make the process of removing the faceplate much easier.
      • Refer to the iOpener instructions for how to heat up and use the iOpener.
      • Apply the heated iOpener to the front of the GoPro for a few minutes to melt the adhesive under the faceplate.
      • The heated iOpener is very hot and can burn your hands. Avoid burns by using towels or gloves to hold the iOpener.
      FixBot'a Sor
      Yorum Ekle
    3. GoPro Hero5 Black Back Housing Replacement: adım 5, 3 resimden 1. GoPro Hero5 Black Back Housing Replacement: adım 5, 3 resimden 2. GoPro Hero5 Black Back Housing Replacement: adım 5, 3 resimden 3.
      • Starting with the edges, use the spudger to pry off the faceplate.
      • The faceplate is held down with adhesive and may take a while to get off.
      FixBot'a Sor
      Yorum Ekle
    4. GoPro Hero5 Black Back Housing Replacement: adım 6, 2 resimden 1. GoPro Hero5 Black Back Housing Replacement: adım 6, 2 resimden 2.
      • Remove the six T3 Torx screws.
      FixBot'a Sor
      Yorum Ekle
    5. GoPro Hero5 Black Back Housing Replacement: adım 7, 3 resimden 1. GoPro Hero5 Black Back Housing Replacement: adım 7, 3 resimden 2. GoPro Hero5 Black Back Housing Replacement: adım 7, 3 resimden 3.
      • Be careful when pulling open the motherboard assembly as it is still connected to the back housing by four cables. The cables may break if stretched.
      • Using the spudger, slowly pry open the motherboard assembly from the LCD side of the GoPro.
      FixBot'a Sor
      Yorum Ekle
    6. GoPro Hero5 Black Back Housing Replacement: adım 8, 3 resimden 1. GoPro Hero5 Black Back Housing Replacement: adım 8, 3 resimden 2. GoPro Hero5 Black Back Housing Replacement: adım 8, 3 resimden 3.
      • Use the flat end of a spudger to pry the three ribbon cables connected to the side of the motherboard.
      FixBot'a Sor
      Yorum Ekle
    7. GoPro Hero5 Black Back Housing Replacement: adım 9, 2 resimden 1. GoPro Hero5 Black Back Housing Replacement: adım 9, 2 resimden 2.
      • Use the flat end of the spudger to pry the battery housing power cable straight up from its socket on the motherboard.
      FixBot'a Sor
      Yorum Ekle
Sonuç
16 farklı kişi bu kılavuzu tamamladı.
Christopher Adams
2.133 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 18-6, Forte Fall 2016 Cal Poly, Team 18-6, Forte Fall 2016 üyesi
CPSU-FORTE-F16S18G6
4 Üyeler
27 adet Kılavuz yazıldı
2Kılavuz Yorumları
Where can you get replacement rear screens for this
ociaravella - Yanıt Paylaş
Hi, how i reset firmware in this gopro? I have a problem with a bucle starting and it dont turn on, always restarting.
ISU AREY - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 37
Son 30 gün: 156
Her zaman: 26,904
