Ana içeriğe geç
GoPro Hero5 Black Lens Assembly Replacement
Neye ihtiyacın var
    1. GoPro Hero5 Black Lens Assembly Replacement, Battery: adım 1, 3 resimden 1. GoPro Hero5 Black Lens Assembly Replacement, Battery: adım 1, 3 resimden 2. GoPro Hero5 Black Lens Assembly Replacement, Battery: adım 1, 3 resimden 3.
      • While pressing the button on the bottom of the GoPro, slide the battery door to the side to pop it open.
      FixBot'a Sor
      Yorum Ekle
    2. GoPro Hero5 Black Lens Assembly Replacement: adım 2, 3 resimden 1. GoPro Hero5 Black Lens Assembly Replacement: adım 2, 3 resimden 2. GoPro Hero5 Black Lens Assembly Replacement: adım 2, 3 resimden 3.
      • Grab the plastic flap on the battery and pull the battery out.
      FixBot'a Sor
      Yorum Ekle
    1. GoPro Hero5 Black Lens Assembly Replacement, Back Housing: adım 3, 2 resimden 1. GoPro Hero5 Black Lens Assembly Replacement, Back Housing: adım 3, 2 resimden 2.
      • Pull and twist the lens cover right or left until it pops off.
      • The lens cover is secured tightly and might be difficult to twist off.
      FixBot'a Sor
      Yorum Ekle
    2. GoPro Hero5 Black Lens Assembly Replacement: adım 4, 1 resimden 1.
      • This step is not necessary but will make the process of removing the faceplate much easier.
      • Refer to the iOpener instructions for how to heat up and use the iOpener.
      • Apply the heated iOpener to the front of the GoPro for a few minutes to melt the adhesive under the faceplate.
      • The heated iOpener is very hot and can burn your hands. Avoid burns by using towels or gloves to hold the iOpener.
      FixBot'a Sor
      Yorum Ekle
    3. GoPro Hero5 Black Lens Assembly Replacement: adım 5, 3 resimden 1. GoPro Hero5 Black Lens Assembly Replacement: adım 5, 3 resimden 2. GoPro Hero5 Black Lens Assembly Replacement: adım 5, 3 resimden 3.
      • Starting with the edges, use the spudger to pry off the faceplate.
      • The faceplate is held down with adhesive and may take a while to get off.
      FixBot'a Sor
      Yorum Ekle
    4. GoPro Hero5 Black Lens Assembly Replacement: adım 6, 2 resimden 1. GoPro Hero5 Black Lens Assembly Replacement: adım 6, 2 resimden 2.
      • Remove the six T3 Torx screws.
      FixBot'a Sor
      Yorum Ekle
    5. GoPro Hero5 Black Lens Assembly Replacement: adım 7, 3 resimden 1. GoPro Hero5 Black Lens Assembly Replacement: adım 7, 3 resimden 2. GoPro Hero5 Black Lens Assembly Replacement: adım 7, 3 resimden 3.
      • Be careful when pulling open the motherboard assembly as it is still connected to the back housing by four cables. The cables may break if stretched.
      • Using the spudger, slowly pry open the motherboard assembly from the LCD side of the GoPro.
      FixBot'a Sor
      Yorum Ekle
    6. GoPro Hero5 Black Lens Assembly Replacement: adım 8, 3 resimden 1. GoPro Hero5 Black Lens Assembly Replacement: adım 8, 3 resimden 2. GoPro Hero5 Black Lens Assembly Replacement: adım 8, 3 resimden 3.
      • Use the flat end of a spudger to pry the three ribbon cables connected to the side of the motherboard.
      FixBot'a Sor
      Yorum Ekle
    7. GoPro Hero5 Black Lens Assembly Replacement: adım 9, 2 resimden 1. GoPro Hero5 Black Lens Assembly Replacement: adım 9, 2 resimden 2.
      • Use the flat end of the spudger to pry the battery housing power cable straight up from its socket on the motherboard.
      FixBot'a Sor
      Yorum Ekle
    1. GoPro Hero5 Black Lens Assembly Replacement, Motherboard: adım 10, 1 resimden 1.
      • Use the flat end of the spudger to pry the black cover plate straight up from its socket on the motherboard.
      FixBot'a Sor
      Yorum Ekle
    2. GoPro Hero5 Black Lens Assembly Replacement: adım 11, 1 resimden 1.
      Bu adımda kullanılan alet:
      • Use the tweezers to pull the ribbon cable connector out of its white socket on the charging assembly board.
      FixBot'a Sor
      Yorum Ekle
    3. GoPro Hero5 Black Lens Assembly Replacement: adım 12, 2 resimden 1. GoPro Hero5 Black Lens Assembly Replacement: adım 12, 2 resimden 2.
      • Remove the two #000 Phillips screw.
      FixBot'a Sor
      Yorum Ekle
    4. GoPro Hero5 Black Lens Assembly Replacement: adım 13, 2 resimden 1. GoPro Hero5 Black Lens Assembly Replacement: adım 13, 2 resimden 2.
      • Use the flat end of the spudger to pry the charging port ribbon cable connector straight up from its socket on the motherboard.
      • Once the ribbon cable is disconnected from the motherboard. The charging port assembly should come right off.
      FixBot'a Sor
      Yorum Ekle
    5. GoPro Hero5 Black Lens Assembly Replacement: adım 14, 2 resimden 1. GoPro Hero5 Black Lens Assembly Replacement: adım 14, 2 resimden 2.
      • Remove the 10mm #000 Phillips screw.
      FixBot'a Sor
      Yorum Ekle
    6. GoPro Hero5 Black Lens Assembly Replacement: adım 15, 1 resimden 1.
      • Remove the charging assembly housing by pulling it straight up off the motherboard.
      FixBot'a Sor
      Yorum Ekle
    7. GoPro Hero5 Black Lens Assembly Replacement: adım 16, 2 resimden 1. GoPro Hero5 Black Lens Assembly Replacement: adım 16, 2 resimden 2.
      • Remove the two 6mm #000 Phillips screws.
      • Remove the two 2mm #000 Phillips screws.
      FixBot'a Sor
      Yorum Ekle
    8. GoPro Hero5 Black Lens Assembly Replacement: adım 17, 1 resimden 1.
      • Use the flat end of the spudger to pry the lens assembly ribbon cable connector straight up from its socket on the motherboard.
      FixBot'a Sor
      Yorum Ekle
    9. GoPro Hero5 Black Lens Assembly Replacement: adım 18, 1 resimden 1.
      • Use the flat end of the spudger to pry the LCD screen ribbon cable connector straight up from its socket on the motherboard.
      FixBot'a Sor
      Yorum Ekle
    10. GoPro Hero5 Black Lens Assembly Replacement: adım 19, 3 resimden 1. GoPro Hero5 Black Lens Assembly Replacement: adım 19, 3 resimden 2. GoPro Hero5 Black Lens Assembly Replacement: adım 19, 3 resimden 3.
      • Use the flat end of the spudger to pry the motherboard off the midframe.
      • The motherboard is held onto the midframe with light adhesive and should come right off with a little force.
      FixBot'a Sor
      Yorum Ekle
    1. GoPro Hero5 Black Lens Assembly Replacement, Lens Assembly: adım 20, 2 resimden 1. GoPro Hero5 Black Lens Assembly Replacement, Lens Assembly: adım 20, 2 resimden 2.
      • Remove the 2mm #000 Phillips screws using a #000 Phillips head screwdriver or tool bit.
      FixBot'a Sor
      Yorum Ekle
    2. GoPro Hero5 Black Lens Assembly Replacement: adım 21, 2 resimden 1. GoPro Hero5 Black Lens Assembly Replacement: adım 21, 2 resimden 2.
      • Pull the lens assembly straight out from the Midframe.
      FixBot'a Sor
      Yorum Ekle
Sonuç
16 farklı kişi bu kılavuzu tamamladı.
Christopher Adams
2.133 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 18-6, Forte Fall 2016 Cal Poly, Team 18-6, Forte Fall 2016 üyesi
CPSU-FORTE-F16S18G6
4 Üyeler
27 adet Kılavuz yazıldı
7Kılavuz Yorumları
RageCams has interchangeable lens mod for hero5
http://ragecams.com/shop/modified-gopro-...
dennis - Yanıt Paylaş
why can't You show how the lens is mount to that assembly? That's the point of it... can we change lenses that way or not?
Polina Luzenco - Yanıt Paylaş
Exactly. Can the actual lens be unscrewed from the mount or it glued / fixed?
contact - Yanıt Paylaş
The lens is heavily glued onto the assembly. It would be far easier to replace the entire assembly than trying to remove that glue.
Christopher Adams - Yanıt Paylaş
the guy who wrote the guide apparently has never heard of pliers. it comes right out, but no idea what the threading is.
mattatron4 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 18
Son 30 gün: 76
Her zaman: 17,924
